Old 12-17-2006, 05:10 PM   #1
Silver Mist
LI Pets's Avatar
Riverhead , New York
Blue power wire fron TV
Now that the old fuse panel is gone and I'm wiring the Wfco power center where do I hook up the blue power wire that goes from the TV thru the 7 pin connector?
Isn't this power wire supposed to charge the battery while driving?
Old 12-17-2006, 05:23 PM   #2
Images: 59
1. Make sure it isn't the brake line. Usually the blue wire is brakes.
2. If it is the #10 AWG charge line, wire it to a 30a breaker, then directly to the battery or to the WFCO 12V power buss.
Old 12-17-2006, 05:33 PM   #3
Silver Mist
LI Pets's Avatar
On '66-'81 the charge line is blue according to the book, so it is the charge line yes.
When you say power buss you mean the + Positive lug, on the panel?
Or the positive lug on the battery.
Old 12-17-2006, 07:30 PM   #4
Images: 59
Attach the charge line to either the battery lug, or the WFCO lug, or the main disconnect switch to the panel; whichever uses the least wire, and as long as the wire has a circuit breaker (or fuse) sized for the wire size.
The charge line, the battery, the WFCO, and the fuse panel should all be at the same potential. There should be overcurrent protection on all the wiring.
Old 12-17-2006, 09:16 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
go to the lug on your converter.
that way you can have lights in the trailer if you have no battery, and happen to be plugged into your tow vehicle.
john
you call them ferrets, i call them weasels.
Old 12-18-2006, 08:06 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
just to add, on my trailer, there is a self-resetting breaker on the charge line, right up next to the 7 pin connector.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-18-2006, 10:48 AM   #7
Silver Mist
LI Pets's Avatar
I'll look around for some type of circuit protection.
Question what controls the amount of charge coming from the TV to the TT batteries?
Will they overcharge if I'm running say 10 hours?
Is the TV alternator going to control the charge to the TT?
I like the idea of going to the power center rather than the battery direct.
Old 01-14-2007, 07:53 PM   #8
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
200 watt plasma tv
Hi all,I have the dream of owening a 29 footer excella soon. I want to add my 200 watt plasma tv above the couch area.Is that possible ,regarding the wireing the in the exiting trailer? thanks firedog.
wbcci ,#3510 NEU & 4cu https://fire1.smugmug.com
firedog is offline   Reply With Quote
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
