01-20-2017, 09:46 PM
2012 25' FB Flying Cloud
Paso Robles
Blue light on shore power inlet out
I noticed that the blue LED lights on both front and back inlets are out. Everything else is normal. Powers up batteries up and all normal readings on plug tester. Any ideas why?
01-20-2017, 10:06 PM
2013 25' FB Flying Cloud
Longmont
The blue LEDs on our trailer (2013 25FB Flying Cloud) have also failed. I have seen multiple reports on this forum about those LEDs failing.
The connection works OK without the lights, so we decided to leave well enough alone and not try to replace the inlets.
I don't know if the LEDs on more recent trailers are more reliable--I hope so.
01-20-2017, 10:31 PM
2015 27' Flying Cloud
Newberg
, Oregon
The blue led on the trailer side of my cord has also failed. Seems to work fine without it.
Mike
01-21-2017, 03:04 PM
Paso Robles
I spoke with factory tech and he said it's usually a dead LED and not to worry about it as long as everything else checks out ok. You have to replace the entire receptacle which is too costly for me. Thanks for you fast replies.
01-22-2017, 12:30 PM
2017 25' Flying Cloud
Florence
, Alabama
Smart Plug
I have a 2017 and the light went out too, underwarranty, but I've decided to install the smartplug outlet. Can't wait to see how it works out.
01-22-2017, 01:31 PM
Paso Robles
dblee1950, would you send a link or reference on the smartplug? Thanks
01-23-2017, 06:41 AM
2016 25' Flying Cloud
Selbyville
, Delaware
The light on my side outlet failed and had it replaced under warranty. Now the front one is out, but everything works. PITA!
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel
WBCCI #9026 Delmarva Unit
01-23-2017, 06:50 AM
Florence
, Alabama
Amazon has the power inlet with the cable plug here: http://SmartPlug B30ASSYNT, 30 Amp I..._PFGHyb0VEV1GR
If link doesn't work just search for it on Amazon. That said, I ordered the inlet and a new power cable for Airstream life store. Only place I could find it. They are slow.. http://store.airstreamlife.com/colle...nt=21381459137
Got tired of screwing with plastic threads
From dblee50 and Southern Belle on the road
The Colonel and Southern Belle
01-23-2017, 06:54 AM
Florence
, Alabama
I also ordered a regular 30amp female plug for my current Airstream cable and plan to make it an extension cable. Camco 55343 30 AMP Female Replacement Receptacle https://www.amazon.com/dp/B00192MU2Y..._URGHybDFRHHKF
01-24-2017, 09:38 AM
Florence
, Alabama
Originally Posted by dblee1950
I installed a smartplug inlet at the front of the camper this am. Forgot to take pictures until I was ready to screw inlet back in. Here are a few:
https://goo.gl/photos/GE68nC6deTcaJFXU9
01-25-2017, 05:29 PM
Florence
, Alabama
