Old 08-21-2016, 07:28 PM   #1
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
blown fuses
this past week, after 4 days of heavy rain, fog and high humidity, I decided that this camping trip was done. I hooked up and had no trailer lites at all. the TV lites all worked. I later found that the 30A fuse between the brake contoller and the battery(+ side) had blown and partly melted the holder. Also, the 40A fuse (- side) between the coach battery and the trailer circuits had blown. I replaced both fuses and now everything works OK! I have a 65 caravel. Any thoughts about the cause here? thanks........joe q
joqin is offline   Reply With Quote
Old 08-21-2016, 07:30 PM   #2
paiceman's Avatar
Upper St Clair , Pennsylvania
Possibly water gone in?
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 08-21-2016, 07:58 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't think the 30 amp fuse is in the brake controller circuit. It is more than likely in the charge line from the TV. Losing the 40 amp fuse could have been the reason for no lights.
But the whole thing looks a bit fishy. Since all of the exterior running, brake and tail lights should be powered by the TV directly. The fuses in the coach should only be protecting circuits inside the coach.
IMHO this should be looked into in some depth.
Old 08-21-2016, 08:02 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Dampness can cause electric circuits to heat up, blow fuses, and burn contacts.
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Blown Outlet Fuses? SuzairMcD Electrical - Systems, Generators, Batteries & Solar 7 11-21-2012 12:14 PM
Converter fuses blown, twice in 2 years, problem? WineStream Batteries, Univolts, Converters & Inverters 10 08-08-2012 04:22 PM
Converter Fuses Blown RangerJay Batteries, Univolts, Converters & Inverters 3 05-17-2012 08:22 PM
Flood, pestilence, and blown fuses... SilverRanger On The Road... 7 07-17-2011 07:01 AM
Blown Fuses daanderson Lights - Interior & Exterior 4 01-11-2009 02:57 PM
