Old 07-09-2015, 01:50 PM   #1
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Blowing fuse on Power jack.
The last time I went to raise the Airstream to hitch up I had nothing when I pressed the lift button on the power jack. Looked at fuse panel and the 20 amp fuse had blow, didn't have a 20 amp so I threw a 30 amp fuse and everything worked fine. A few weeks ago same problem fuse blown. Only thing I did notice is that the propane cover was riding on the wire coming from the power jack on top of the hitch and looks like it might pinched.
Any ideas Thanks Jim
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 07-09-2015, 02:05 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you pinched a wire and had a short at that point there should be a burned spot as a result of the short. In any case either reroute or cover that wire at that point.
2004 Excursion 4x4
Old 07-09-2015, 04:03 PM   #3
HowieE's Avatar
Images: 12
On second thought.
If there was a short you should cut the wire at the short and re-splice it because the wire diameter may have been reduced during the short.
2004 Excursion 4x4
Old 07-09-2015, 05:29 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Make sure you are using Slow Blow 30 amp fuses. Start up current draw is pretty high. They can be difficult to find. NAPA stocks them.
MICHAEL
Old 07-09-2015, 06:14 PM   #5
2010 25' FB Flying Cloud
Davenport , Iowa
Tell me about it, in my case the inline fuse holder had separated just enough to loose contact. I than fund that the tank cover was "shorting " the wire so there was pull that caused the separation. I now carry not only extra fuses, but a 1/4 in drive extension(10 inch) and ratchet in-case i have to jack the trailer manually. The adapter supplies was too short.
mike
Airtandem is offline   Reply With Quote
Old 07-09-2015, 06:21 PM   #6
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
mike
I have an extension for mine for the same reason, but it's 3/8 drive.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 07-09-2015, 06:23 PM   #7
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
mike
Do you think an 18 volt drill with a 1/4 drive would work in a pinch?
Sjcjr is offline   Reply With Quote
Old 07-09-2015, 07:36 PM   #8
AWCHIEF's Avatar
Images: 33
It will work but will suck a marginal battery down quickly. I have used mine but my batteries are several years old and are getting tired. I also keep several extensions in the tool box so that I can clear the propane cover.
MICHAEL
Old 07-09-2015, 08:49 PM   #9
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Put several thick flat washers under the aluminum brace inside the bottle cover to lift the cover up off the wires. Otherwise it will continue to rub through the wires.
Amazing that nearly every trailer that has rolled down the line has virtually no clearance between the tank cover and frame. Guaranteed pinched wires.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 07-09-2015, 09:26 PM   #10
AWCHIEF's Avatar
Images: 33
I put several inches of shrink wrap on my wires and wraped even more electrical tape around them. Still do not care for where they run. Keeping thinking I will reroute them, just never get around to it.
MICHAEL
Old 07-10-2015, 12:38 AM   #11
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We've learned that a Low Bat condition will blow the jack fuse every time.
Separately, our jack was having intermittent failures - turns out we had two problems. First, the switch was going bad. Second, water was getting into the in-line fuse from the top and corroding the fuse and its contact. Since our unit is still under warranty, Uncle Wally replaced both at no additional cost to us, and now the jack is again dependable as long as we have enough charge on the batteries.
Rocinante is our 2014 International Signature 27FB
Old 07-10-2015, 11:59 AM   #12
The Villages , Florida
I had the same problem. It was caused by raising the Jack to high. The fuse blows to protect the Jack. Since I now stop the Jack lower I have never had another problem.
hacienda2 is offline   Reply With Quote
Old 07-10-2015, 12:49 PM   #13
HowieE's Avatar
Images: 12
If the jack was a quality jack, and unlikely with a newer trailer, it would have limit switches at each end to stop the jack before it could stall the motor.
Just found an LCI jack on my daughters new trailer without limit switches after a blown fuse. Called the company and they said they don't use limit switches any longer we are supposed to watch the jack and stop it before it stalls.
Buyer Beware because they are selling junk now days.
2004 Excursion 4x4
Old 07-10-2015, 03:03 PM   #14
Skater's Avatar
1995 30' Excella
Bowie , Maryland
...or his jack is indexed incorrectly.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 11:38 AM
Fuse blowing and sparking! Lily&Me Batteries, Univolts, Converters & Inverters 7 07-27-2009 02:18 PM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 09:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 06:54 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 01:25 PM
