Old 07-11-2015, 07:34 AM   #29
dznf0g's Avatar
Oswego , Illinois
Originally Posted by AWCHIEF View Post
Suppose you are referring to my post. I did not tape the already water/weather proof inline fuse holder. I put the shrink wrap and tape where the wires were getting pinched between the frame and gas box. This morning I followed the suggestion to add washers under the mounting bracket. It seemed to make the box loose fitting and sloppy. Not happy with the result so I removed them. As soon as the temp dips below 90 I am going to mess with it some more. Got to be a better way than it comes from the factory. Projects and fiddling never ends.
I took sections of 3/8" automotive fuel hos and split them lengthwise. I placed them on the bottom of the propane cover at the areas where they ride on the a-frame and jack plate. This allows space between the cover and the wiring, while allowing for a tight fit of the cover. No movement at all.
BTW, I ENJOY projects and fiddling, but I'm built that way. Celebrate them, if you can.....
-Rich-
Old 07-12-2015, 06:51 AM   #30
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Another great idea, thanks.
MICHAEL
Old 07-13-2015, 07:27 AM   #31
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We took a short piece of 1/2" Pex tubing, spray painted it gray, and fed the wires through it as protection. We also used some washers to raise the tank cover a bit for clearance. The only problem with our solution is that the paint is wearing off the Pex, as you would probably expect. But I'll take that problem over the fire we had from the shorted wires...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-13-2015, 07:42 AM   #32
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, last time that I looked at new Airstreams, instead of re-routing the wires like I did, they cut a huge hole in the propane tank cover. Sometimes, I would like to show them a few things on my trailer that they should do. Simple things that make our trailer nicer and are not expensive fixes.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-13-2015, 10:22 AM   #33
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Can't help but think that the folks that design them don't use them.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 07-14-2015, 11:22 AM   #34
1996 25' Excella
Tillsonburg , Ontario
Just a bit of experience re painting Pex or plastic. Krylon paint will stick and weather very well.
Our tank covers were adjusted by some dealer using washers and nuts after they moved the regulator up from its location at the bottom of the threaded rod. The factory install is simply very amateurish. The easy way is not always the most utilitarian. I plan to completely rework the assembly so it sits still and works without a struggle while changing tanks.
jcw
JCWDCW is offline   Reply With Quote
Old 07-16-2015, 08:22 PM   #35
Salem , Oregon
Images: 18
jcw
Hi, I posted pictures before, but I don't have them right now; What I did, was to lower the cross bar to the inside of the tank handles instead of on top. Then I made spacers for the tank cover. Now I tighten my tanks first, then tighten my tank cover last. Now both the tanks and the cover are always tight. Airstream made it so you would tighten the tanks and cover all at the same time, but I found that one or the other would be loose. I wasn't happy with that arrangement.
2005 Safari 25-B
Old 07-19-2015, 10:09 PM   #36
WaLee's Avatar
Nevada City , California
I was blowing my fuse too often. Took the Dremel to the cover and duplicated the cutout the AS is doing in the new trailers and re routed the wire so that my PP jack U bolts weren't impinging the wire so far so good.
WaLee is offline   Reply With Quote
Old 07-19-2015, 10:10 PM   #37
WaLee's Avatar
I use a nut to tighten the tanks down, then put the big wing nut down so the cover will stay latched.
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 10:38 AM
Fuse blowing and sparking! Lily&Me Batteries, Univolts, Converters & Inverters 7 07-27-2009 01:18 PM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 08:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 05:54 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 12:25 PM
