Old 06-14-2006, 08:15 PM   #1
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Exclamation Blinking lights!!!!!
HELP!!!!!!!! Brooke and I were packing up the Sovereign this evening, in preparation for the trip tomorrow. We had both Fantastic fans on, as well as the three hall lights and the bathroom light. All of a sudden the interior lights started blinking, not fast though. They would go dim for about five seconds, then get bright for about one second and then dim again. The trailer was plugged into the truck, so I started the truck up and the blinking got a little quicker.
The battery is a new AGM, and the charger is a new IOTA. I have had electrical problems, since I've gotten it back from the shop, and the last time I took it to them, they recharged the AGM and put a cutoff switch, which I've been using, when it's in storage.
When I disconnected the trailer from the truck, the lights stopped blinking, but they are kind of dim. They did have to rewire the harness to match the Ram, and the running lights and brakes do work. When it's plugged in, the IOTA's smart charger is blinking.
What the heck is going on here?????? Any theories? Short of getting a spare battery tomorrow, I don't know what to do.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 06-14-2006, 09:07 PM   #2
San Angelo , Texas
Images: 37
No one?
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 06-14-2006, 09:42 PM   #3
1976 25' Caravanner
Campton , New Hampshire
Not sure if this will help or not , it seems to fit some of your situation but not all . When you first start a Dodge diesel there is an intake heat grid that will cycle on and off for the first few minutes . When it does this the lights will dim on and off because it draws a lot of current . Why it would do this with the engine not running is a mistery . Unless the key was in the run position and the engine wasn't running.
ticki2 is offline   Reply With Quote
Old 06-14-2006, 09:59 PM   #4
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
I'm not an electrical guru either but...
Were you used to it being plugged in to shore power?
I have a good battery in my trailer but the lights will grow noticeably dimmer when I unplug it from the power pole. Utilizing another electrical item will also cause the lights to dim.
Dunno...
Ultradog is offline   Reply With Quote
Old 06-15-2006, 04:28 AM   #5
San Angelo , Texas
Images: 37
ticki2, yeah I thought about the heater grid too, but that's not it. The truck wasn't on at all, when the lights started to blink dim.
ultradog, I'm used to shore power and boondocking. It's not that the lights were just dimmer, they were actually blinking dim, then bright, then dim, etc...
I'm still stumped.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 06-15-2006, 04:35 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
frederic
you may want to recheck your hitch connections, it sounds like the dimming you describe is a thermal breaker cycling in the trailer.
pay particular attention to the charge line and ground positions on the plug.
good luck and i hope it doesn't delay your trip much!
john
you call them ferrets, i call them weasels.
Old 06-15-2006, 05:29 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Our coach does that when I have too many things on at once. There are two self-resetting circuit breakers that will cycle on and off as you describe. Check with the shop that did the electrical upgrades, and see if they installed circuit breakers.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
