Old 12-16-2013, 08:18 AM   #1
Land Cruiser
2008 25' Safari FB SE
Lake Jackson , Texas
Black goop
I am doing some rewiring and need to seal the large hole in the floor where a wire bundle comes in. What is the black goop that Airstream uses to seal around wires? My AS is 5 years old and the factory sealant is still pliable so it appears to be really good stuff.
Roland
Roland62 is offline   Reply With Quote
Old 12-16-2013, 08:34 AM   #2
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
It may be Vulcan Sealant
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 12-16-2013, 08:37 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I was told it is Sikaflex, a one part polyurethane adhesive, sealant. You cab find it at boating places like West Marine.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-16-2013, 10:14 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Larry
There are six different compounds each bearing the Sikaflex name. Three of them are primers, and one is a two-component system. One is only available in white (but cures to a light gray color, subject to yellowing as it ages).
The one you want is probably Sikaflex 15LM. It's also available in colors, so you can get Sikaflex 15LM in Aluminum Gray as well as in Black and other colors (but avoid lighter colors; they tend to yellow as they age). No primer required for non-porous surfaces. Here's a link to the product data:
http://usa.sika.com/dms/getredirect....s.sika.com/266
Cats and ultraleather Airstream upholstery don't mix!
