Old 07-01-2019, 02:15 PM   #1
VDR928's Avatar
2012 23' FB International
Charlotte , NC
BIG Problem with 2019 GMC truck sith Furrion back up camera
Beware that the 2019 GMC (Sierra 1500 DENALI) will NOT work with the Furrion cameras We ordered one from Furrion per Amazon (600.00). Furrion will not refund it nor will Amazon! We installed it and it worked perfectly for a week until we traded tow vehicles. It is a known problem that The 7 way does not put out 12 volts. 600.00 paperweight!!! Anyone know how hard it would be to fish a wire to the 12 Volt by the DVD player back to the camera? We had no trouble wiring to the lights but now we have to do it all over. We REALLY REGRET BUYING THIS BACK UP CAMERA! What a Father's Day gift!!!
VDR928 is offline   Reply With Quote
Old 07-01-2019, 02:19 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Search for the thread on this. There is a pretty simple fix identified by Rich. GM understands but no fix is imminent for 2019.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-01-2019, 07:03 PM   #3
VDR928's Avatar
Charlotte , NC
Larry
Thanks, Larry. We read that and it was clear as mud for us. Can someone explain it better? We can get to that area but then don't understand what to wire to what?
2012 23FB International Serenity #Dorytheairstream
2019 GMC Sierra 1500 Crewcab 4WD Denali
"Denali & Dory"
Old 07-01-2019, 07:25 PM   #4
dznf0g's Avatar
Oswego , Illinois
Without knowing what model, and what 12v items you have in The rear, I cant tell you where to tap into for a 12 v feed. But all you need to do is get a lower amperage relay. Tap the control side ( the coil which closes the relay) into the taillamps circuit, so you can use your park light switch in the TV to turn the camera on and off. Tap the load side of the relay into any convenient source which has power at all times. The relay (control side) is so slow, ie, old school that the pulse will have no effect on trying to open and close the relay. Old school mechanical device to the rescue on a modern oversight.
-Rich-
Old 07-02-2019, 06:38 PM   #5
2007 25' Safari FB SE
South Bend , Indiana
Furrion will be releasing a new 7-way harness adapter that will plug in between the tow vehicle and your Airstream this will fix the problem and allow you to use the Vision S cameras. Harnesses will be available in three to four weeks.
Kapamumu is offline   Reply With Quote
Old 07-03-2019, 04:49 AM   #6
VDR928's Avatar
Charlotte , NC
Furrion Engineers have the Solution!!
UPDATE: My husband and I have never before received such great customer service! Furrion's "head of customer relations" called my husband and their engineers have a fix for this problem. It is a simple adapter that they have tested and it works. It plugs in the 7 way and boosts the voltage to the camera (ours is wired to our running lights). To top it off they are overnighting it and sending it free. We are overwhelmed with the service. It is not their issue (it is GMC's) and yet they have worked out a fix. Rarely, if ever, have we had THIS sort of exemplary service. We have contacted and written reviews on Furrion's service and this adapter everywhere we can think of... even contacted GMC's Auto Engineer, Daniel Cohen. If you know of anyone with this problem or owners of Airstreams struggling (like we were) with a solution please let them know Furrion has the answer!
"Denali & Dory"
Old 07-05-2019, 11:11 AM   #7
VDR928's Avatar
Charlotte , NC
We have now traveled over 800 miles with the Furrion prototype adapter for the 2019 GMC attached to our 7 way. We have traveled through mountains, heavy thunderstorms, rough roads, and construction and the adapter has not so much as hiccuped! We have a crystal clear picture and feel much safer being able to view the rear of our Airstream.
We had no idea how to fix this problem with the “Special Technology” in our new truck. While we LOVE the trailering features the truck offers, one caveat was not being able to get a constant 12 volt charge to use that camera on the back of our Airstream. Furrion's engineering has solved our problem with this adapter. We have been informed it will be offered for sale in 3-4 weeks.
"Denali & Dory"
GMC 1500 AT4 2019 & Airstream Classic 30RB 2019 mikebrownvb Towing, Tow Vehicles & Hitches 54 07-15-2019 11:33 AM
Big Truck + Small Trailer: ease of install, hitch, unhitch, back up / sway /WD / cost reverie room Hitches, Couplers & Balls 39 12-13-2018 01:55 PM
I've got a big beef!!! And big bug problem! turk123 Airstream Lifestyle 43 11-10-2018 05:41 PM
Dealer wants to install a Furrion backup camera on 2018 sport? Cvinson Audio, Video & TV 18 08-26-2017 10:35 AM
Back up camera problem Pocallaghan 2005 and newer - Bambi all models 2 06-29-2017 07:30 PM
