Old 11-12-2005, 03:03 PM   #15
Images: 59
Tom,
I agree that calling it a two phase system is awkward terminology Usually we talk about either single phase or three phase.
That said, technically there are two 120v 'phases' is 240v systems. This is referenced in the code.
I prefer referring to them as the black and red legs.
Old 11-12-2005, 03:04 PM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
old lineman saying: if you don't know what it is don't touch it!
I believe 220 VAC is considered single-phase power from a lineman's perspective.
tom you are correct, a 240 volt service with 3 wires is single phase in lineman speak. however, each hot wire is considered a seperate phase.
a three phase service would have 3 or 4 wires depending on weather it was delta or wye connected.
here is a partial list of what you can get from the power company:
120v single phase 2 wire
120/240v single phase 3 wire
120/240v 3 phase delta 4 wire
240/480v 3 phase delta 3 wire (no neutral)
120/208v single phase 3 wire (network)
120/208v 3 phase wye 4 wire
277/480v 3 phase wye 4 wire
john
you call them ferrets, i call them weasels.
Old 11-12-2005, 03:06 PM   #17
1974 25' Tradewind
Yelm , Washington
Thank you Mark. I, in this case was forced into learning some things that I did not previously know. That is the most important thing, and what I value most from this group, that I (we) learn things from each other that can save us time, money or health and safety.
I am a health adviser (communicable disease expert) and often times am entering buildings with other experts such as police, electrical inspectors, building officials, housing authorities etc. to determine if a structure is suitable for habitation.
In lockstep with the building guys I see a lot of really dangerous wiring jobs done by people who do not install it right. I am also required to compare notes with state fire Marshall's after buildings are leveled by poor wiring, and that is not a happy business I can tell you.
I came to this thread with a filter on, granted, and I think that is what you picked up on. I apologize for the passion on this subject but as you see, alot of this funnels past me at work so I am, perhaps, overly cautious, not knowing how much the person asking the advice knows.
Thank you for your kind patience and explaining and better clarifying the 110 and 220 load/shared neutral/ground scenario. I was thinking 220 and did not know that besides newer 50 amp 220 hook ups, 30 amp 220 is not done.
Anyway, I was not irritated just ignorant, wanting to be sure and telegraphing caution.
Thanks again. Thank you Squirrelly and good luck on your coach !
"It takes a village to raise a silver twinkie."
-Jim Phillips
JimmyJames is offline   Reply With Quote
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Doctor Box Pahaska Our Community 7 11-18-2002 08:53 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
