Old 05-28-2012, 08:13 PM   #15
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
plugs and outlets... ...The good ones have quality brass plug legs and sockets
Actually the best ones have a hard red copper alloy plug & socket prong & contact pieces that are brass coated.. Brass is too soft, tight friction fits shave metal and the plugs bend too easy!
Old 05-28-2012, 08:14 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by project66 View Post
Well, I got the load center in this weekend and the A/C and new microwave outlet work fine, but I noticed something missing. I've done enough home wiring to know there should be a heavy gauge copper wire going to ground. Should I run a similar ground to the frame, or is everything grounded "enough" with all the outlets rivited to the body? I just want to make sure before I button things up.
TomE
Need a heavy ground from the panel to the frame. I was just disassembling mine this weekend and there is a #10 solid from the power panel down through the floor to the frame outside for a ground.
Aaron
WBCCI #XXXX AIR #2495
Old 05-29-2012, 05:08 AM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Found an interesting fix for my issue with a the long cord. I can simply pull some of it into the interior of the trailer thru the hole in the bottom. Now it all fits back in the compartment without having to force the hatch shut to latch it.
MICHAEL
Old 05-29-2012, 08:59 AM   #18
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Clever solution, AWChief!
Skatiero is offline   Reply With Quote
Old 05-29-2012, 09:56 AM   #19
AWCHIEF's Avatar
Images: 33
Thanks, just a lucky find. I was actually doing something else when I noticed where the cable came thru the underside. Gave it a pull and it came right in. It is under the couch and there is plenty of room behind the water tank to store the excess cable.
MICHAEL
Old 05-29-2012, 10:13 AM   #20
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I took my original cord and cut it. I put one of the new shore hookups on the outside of my drivers side rear and then plug the rest of the cord in there. (Just like the New Trailers) All I needed was the plug for the side of the trailer and used my original 25ft cord. It probably about 18 ft now on the outside but has never been to short..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 05-29-2012, 08:18 PM   #21
1966 26' Overlander
Conover , Ohio
Well, I think I am going to go with a fairly short power cord, 15 ft or so. This is a pic of the corner where the cord will have to be stored. It looks like there will be too many things to get caught on even though I plan to clean things up a bit.
I did find a pic of the old load center and it did have a ground wire. It just got lost in "the pile". I took about 400 pics while I was tearing the old 66 apart. The best move I ever made.
Thanks for all your input. TomE
project66 is offline   Reply With Quote
Old 05-29-2012, 10:11 PM   #22
Mexray's Avatar
1978 28' Ambassador
Morada , California
Our 78 had the permanently attached, 25ft power cord that lead out of the bumper...Here's what I did to 'upgrade' to a removable, late style shore power cord:
http://www.airforums.com/forums/f173...way-41888.html
Go down to post #44 & 46 for some pics and part number info, etc...
I don't know if this would be applicable to your particular AS...It was a relatively easy project, and it's a BIG improvement when dealing with the power cords!
I use a short 'adapter' cord at home that plugs into the AS and has a male 20amp connector on the other end...I use a heavy 10/3 extension cord from the adapter to the house for power, and leave the heavy 30amp RV cord stowed away for use on the road...
Name:	Power cord conv.JPG
Ray & Pat; Morada, CA
