Old 01-16-2016, 10:15 PM   #1
Petaluma , California
Best way to use solar w/ shore power
Hello,
I just purchased an airstream w/ solar panels. I'm trying to figure out the best way to use all that free/renewable power on our roof. Our rig does not have an inverter (as far as I can tell).
The only way I can think of is to unplug the shore power and use the charged up battery. Is there any kind of switch inside the AS?
Our's is a 2013 30ft signature
Cheers
DQ
dquirk29 is offline   Reply With Quote
Old 01-16-2016, 11:21 PM   #2
2015 30' Classic
Pleasanton , California
You should have a battery disconnect switch that's labelled Store/Use. When you're connected to shore power, you should disconnect the batteries and let your converter supply 12 V to your trailer. You solar panels are still charging the battery even in the Store position. The solar charger is a much better charger than your converter, so when connected to shore power, keep in the switch in the Store position and you're batteries will last longer.
When you're boondocking without shore power or when you're travelling and want the fridge to cool, you'll need to select the Use position. This will re-connect your batteries and supply 12 V to the trailer.
Good luck with your new Airstream and ask away if you have more questions.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 01-17-2016, 07:03 AM   #3
dznf0g's Avatar
Oswego , Illinois
This isn't always true. Some ASes have a battery isolation switch and some have a house isolation switch. My switch disconnects all house circuits from the battery and converter. If the converter is plugged to shore power, the batts are still receiving power, but the house is not. Since my positive busses are upstream from the cutoff switch, solar is always on regardless of switch position. And yes, that configuration is factory. My only change was to move the propane detector from the positive buss to the fuse panel for the house so it's not powered while in storage.
-Rich-
Old 01-17-2016, 07:28 AM   #4
All of my outlets still work while I have it in the store position so I assumed shore power was still being used for the fans etc..
Al, just so I understand, you are saying while in store mode the AS is like a giant extension cord for all the outlets and oven?
DQ
Old 01-17-2016, 09:11 AM   #5
Sorry one more question, until the next one
When I am plugged in on shore power and have the AS in store mode. The batteries on the tongue are charged from the solar panels? Is that correct?
DQ
Old 01-17-2016, 09:35 AM   #6
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . welcome to our group, you ask good, specific questions, keep them coming ! regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 01-17-2016, 09:58 AM   #7
2015 30' Classic
Originally Posted by dznf0g View Post
This isn't always true. Some ASes have a battery isolation switch and some have a house isolation switch. My switch disconnects all house circuits from the battery and converter. If the converter is plugged to shore power, the batts are still receiving power, but the house is not. Since my positive busses are upstream from the cutoff switch, solar is always on regardless of switch position..
This is good to know. What year did AS switch over to the current configuration?
Al, K6IV
Old 01-17-2016, 10:00 AM   #8
2015 30' Classic
DQ
Correct. In your model the solar charger is connected directly to the batteries regardless of the position of the Use/Store switch.
Al, K6IV
Old 01-17-2016, 10:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
I don't know...I assume it is model run driven. I believe the Excellas and Classic 30/31s were like that up to 2015. I don't know if they changed the Classics with the new configuration. Other 30'ers????? I don't know either.
-Rich-
Old 01-17-2016, 10:39 AM   #10
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Great conversation! It has encouraged me to dig into tha manuals and start measuring voltages.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 01-17-2016, 10:46 AM   #11
Rico2surf
Medford , Oregon
I have a sub-question based on this conversation, so hope that's not contrary to protocol. I have a '73 overlander 27', and we stay in the summer at a ranch without hookups, so we have a portable solar charger (Zamph?) to keep the battery charged (which works very well by the way). In the winter we keep it at an RV site on the coast (So. Oregon) with hookups. Question is, based on your comments above, should I disconnect the battery all winter while on Shore Power to save battery life?? We do not have any of the finer improvements of switching on or off; we have to physically disconnect the battery cables. If your suggestions is YES, disconnect, then is it necessary to disconnect both positive and negative cables?? Thanks so much !!
Richard
rico2surf is offline   Reply With Quote
Old 01-17-2016, 12:08 PM   #12
2015 30' Classic
rico, sounds like you have a couple of options in Winter if your connected to shore power for extended periods:
1. Best to not let your converter charge the batteries with a single-stage battery charger. So simply disconnect your battery. It's only necessary to disconnect one of the battery terminals and the preferred terminal to disconnect is the negative terminal (if you accidentally short out the negative terminal to the chassis there's no harm done). Some folks remove the negative terminal and wrap it in a latex glove for insulation.
2. Another option if you're connected to shore power for an extended period is to upgrade your converter to a three-stage battery charger. This way battery will not be overcharged.
3. Another option, would be to rewire your trailer as is done in the current AS models such that when the battery disconnect switch is in the Store position, the converter is connected to the main 12 V bus but the batteries are disconnected. In you case the portable solar system would connect directly to the batteries and happily charge the batteries during Winter.
Al, K6IV
Old 01-17-2016, 12:51 PM   #13
baterup's Avatar
2016 27' Flying Cloud
Palmdale , California
Great Q&A's guys, thanks for the experience...
baterup is offline   Reply With Quote
Old 01-17-2016, 04:32 PM   #14
2015 23' FB Flying Cloud
Redmond , Washington
Great information. After much study I plan to swotch out the stock converter on my 2015 FC 23FB. Does anyone have a recommendation for a particular 3-stage converter? What is approximate cost? Can someone who has average electrical (installing seitches snd fixtures in a house) knowledge do this?
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
