Old 08-10-2014, 07:54 AM   #1
1973 31' Sovereign
Robinson , Texas
Best way to run 50amp to exterior
I need ideas for running my 50amp elec cord from inside the trailer to the exterior for plug in. The trailer was gutted when I got it so I'm not sure how it was originally. Not to worried about keeping it original so I am open to any ideas. Thanks
Projecttinca is offline   Reply With Quote
Old 08-10-2014, 09:23 AM   #2
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
We have a second A/C unit on our '34 Limited that was added after the fact, so it has it own separate cord with 30 amp plug. There is a small cubby in the rear trunk that houses the dedicated 30 amp breaker box and the length of cord, then on the rear exterior streetside corner they drilled an access hole and mounted an RV electrical cover/cap for the cord to come out and run to the plug in's. When not in use the cord just retrieves into the access and the plug end stores just inside under that cover. I dont really like the ugly white plastic look of it, but, it's not THE ugliest thing on the exterior of the AS, so I live with it.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 08-10-2014, 10:29 AM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
This is a little pricey, but it may be what you're looking for: 50 Amp 125/250V Stainless Steel Easy Lock Shore Power Inlet - Marinco | Fisheries Supply
or
http://www.fisheriessupply.com/hubbe...-250v-hbl504ss
Old 08-10-2014, 10:40 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Try this been running fine.
http://www.airforums.com/forums/f37/...ml#post1323667
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-10-2014, 03:43 PM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Here is a manufacturer of the equipment used by Airstream with a link to the 50 ampstuff.
Furrion Store | Electrical | Power Cordsets
I have used many variations of their pigtails and cables.
switz is online now   Reply With Quote
Best way to run a generator GettinAway Generators & Solar Power 33 09-19-2013 06:33 AM
50amp Conversion / Addition TomR Electrical - Systems, Generators, Batteries & Solar 6 11-03-2007 12:07 PM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
Power Inlet 50amp markdoane Electrical - Systems, Generators, Batteries & Solar 4 10-14-2005 08:25 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
