Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-30-2015, 05:34 AM   #21
65CV's Avatar
Western , Massachusetts
We've had the Yamaha 2400 for about 4 years now. We don't need to run it often and have had no issues with it. It just starts and runs. Bought the converted unit from US Carburetion.
65CV is offline   Reply With Quote
Old 10-30-2015, 05:44 AM   #22
Bauxter's Avatar
Sunset Beach , North Carolina
Originally Posted by Streamracer View Post
I use an Onan 2500 watt RV Genet that I fabricated a carrying frame and enclosed it with alum skins. I hook up to my bottles on the trailer. I have the option to run at the ac or micro. It is nice not having to go outside to start it and is also quiet. Been using it for several years. I understand the new models are self diagnostic so if you have a problem you know what it is. It is heavier and not cheap. Most don't realize that switching from gas to propane the power is derated. That being said, the 2800 watt is the same unit running on gas.
Streamracer, Do you have a thread for your trailer? I would love to see pics of how you engineered the genset housing.
mike
Bauxter is offline   Reply With Quote
Old 10-30-2015, 12:34 PM   #23
sws323tt's Avatar
2014 28' International
Savannah , Georgia
Propane genertor
My understanding is 1 gallon of gasoline is equivalent to 1.3 gallons of propane.
sws323tt is offline   Reply With Quote
Old 10-30-2015, 01:02 PM   #24
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Do you have the version that allows you to run both gas and propane or the version that eliminates the ability to run on gas? AND are you happy w/ the version you have?
Thanks, Markr
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-30-2015, 09:59 PM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Perhaps you should consider an alternative - instead of getting a propane-powered generator and running your furnace, simply get this: http://www.amazon.com/Pro-Com-Dual-F...=procom+heater
I boondock in the desert, and the temperature drops to freezing at night. So I installed this blueflame heater. It is a convection type of heater, and heats my entire 32' AS from front to back. I do have the galley window cracked open and the vents over the stove and in the shower stall open to provide oxygen. I would add that the blueflame heater is the heater of choice among the boondockers I know.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 10-31-2015, 08:25 AM   #26
Tincampers's Avatar
Sneedville , Tennessee
I'd be interested in learning more about this. Could you start a new thread and show where you mounted this and how you tapped into the propane lines?
Tincampers is offline   Reply With Quote
Old 10-31-2015, 08:28 AM   #27
Tincampers's Avatar
Thanks, Markr
We have the 2400 that was converted to tri-fuel. It works great. I use only propane though as I don't want or need to carry gasoline. It always starts on the third pull and will run the hair dryer, microwave and the air conditioner. Not at the same time though!
Old 10-31-2015, 09:45 AM   #28
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
do you have the thermostatically controlled version? and if yes, w/out a power hook up, how does it "re-ignite" on it's own? or does the output just drop way low when the trailer is warmer than the set temperature? . . . or does the thermostatically controlled version need power?
thanks, markr
Old 10-31-2015, 05:23 PM   #29
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
thanks, markr
Yes, I have the thermostatic one (it is actually less expensive than the hi-lo version I previously had in my LY moho). It has a pilot light, so there is no electricity whatsoever involved.
As for the installation, the PO of my AS had had a catalytic heater installed. All I did was remove it and put the blueflame in the same location.
It is necessary to have a propane line brought to the place you want to install the heater. To do this safely (and without compromising your insurance), have it done by a licensed gas technician. The job is not very difficult - it just requires splicing a tee into the existing gas line (remember that they use flared fittings) and running it to a shut-off valve and then to the propane connection at the bottom of the heater.
After the Halloween kids have gone to bed, I'll snap a picture of mine and post it.
VE3JDZ
AIR 12148
WBCCI 8080
Old 11-01-2015, 04:51 PM   #30
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Here is the photo of the mounted blueflame heater.
VE3JDZ
AIR 12148
WBCCI 8080
Old 11-01-2015, 05:50 PM   #31
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Does anyone use a 1k generator connected directly to the battery to charge rather than using the converter? I know you can not run other 110 things this way but can you charge your battery more quickly. When boondocking I hate to hear any generator run even my own.
Jonathan Hettrick
'92 Excella 29'
'20 Ram 2500
AIR # 59179
Chillpoints is offline   Reply With Quote
Old 11-01-2015, 05:55 PM   #32
65CV's Avatar
Thanks, Markr
We have the gas/propane option and I'm very happy with it. That said, I did have to adjust settings between the two versions to run the A/C on our old A/S. I have settled on settings now and don't change them. I never use gas anymore. We use quick disconnects to hook up the generator to the inactive propane tank.
Old 11-01-2015, 07:17 PM   #33
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I have run my 2000 honda all night while the furnace was on , it was down to 18 degrees with a high wind, it was still running when I shut it off almost 9 hours later, all is well...
Old 11-01-2015, 07:19 PM   #34
1974 Argosy 20
Kooskia , Idaho
I have a 1 KW Honda. The direct charge is only about 8 amps and is unregulated, that is it is a poor charger.
It is much better to use the built in converter/charger with power supplied by the Honda. It will charge at a considerably faster rate.
Old 11-01-2015, 07:41 PM   #35
interstateflyer's Avatar
2017 25' International
Los Osos , California
Do you guys feed your generator output through the trailer's tow vehicle umbilical cord?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-01-2015, 07:59 PM   #36
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
It is much more advantageous to hook up the trailer's electrical cable to the generator and let the trailer converter/charger charge the batteries. You can use a 30AMP/15 amp adapter
This summer I stayed in Pilot Flying J RV parking more than once. Each time I ran my generator all night as it was humid and rainy. A few times I walked into the store section to return noting how I could barely hear the generator until almost standing at the trailer.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 11-02-2015, 11:42 AM   #37
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
That eco mode on the Honda eu2000i is pretty amazing. I have found I can run ours all night with 1 tank of gas. I'll start it at 9pm and put it in eco and it won't run out until 5 or 6 in the morning.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
Keep Refrigerator on electric while traveling Fred2 Batteries, Univolts, Converters & Inverters 42 10-04-2015 06:33 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Turn off propane while travelling? Belbein On The Road... 27 04-28-2014 11:24 AM
