Old 10-29-2015, 03:04 PM   #15
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Originally Posted by interstateflyer View Post
I'm looking for a propane powered generator when dry camping for those very cold nights when I have to run my gas furnace ...............
Since I don't know what you are calling "very cold" my comment may not apply. However remember that propane vapor pressure drops in cold weather so you have less propane flow available to you. One chart I have shows a 30lb cylinder that is 25% full will flow 32,000 BTU per hour at 60F and only 10,000 BTU per hour at 0F. Before relying on a propane powered generator you might investigate the propane usage of the generator and furnace combined if you plan to run off the same tank.
We travel regularly in sub zero temps so carry gas generators as back up.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 10-29-2015, 03:24 PM   #16
interstateflyer's Avatar
2017 25' International
Los Osos , California
As a matter of fact, we are planning a trip to Alaska in May, June and July. I was thinking nights in the 20s and 30s.
Your point about decrease propane flow is well taken. Thanks.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-29-2015, 03:49 PM   #17
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I would consider gas first then. You are not going to want to empty those tanks and find yourself miles away from someplace to fill up your propane. Reading the above document, it looks like running the generator plus furnace would empty the tanks at a significant rate.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-29-2015, 05:02 PM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Phoenix View Post
Just curious, how long will a generator run on a 30# propane tank, versus being refueled from a six gallon portable gas tank?
In cold weather, is it a concern that propane (for the furnace) is being consumed faster with the use of a propane-fueled generator?
15-20hrs depending on load....1.5lb
Name:	LIQUID STAINLESS STEEL 281.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-29-2015, 07:33 PM   #19
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I carry two Honda EU 2000s (one regular, one companion) both with the Propane Carbs conversions on them. https://www.propanecarbs.com/honda-e...onversion.html Here in Fla we mostly need AC, not heat, and the two Hondas will deliver that. They are not capable of running the converter (a 55 amp Progrssive Dynamics) and AC and Microwave simultaneously.
I have run any tests on this configuration and posted results in various Airforums threads. To summarize some findings:
- At 1,600 watts of load (their rated maximum for sustained operation) these generators burn about 2 lbs of propane per hour.
- I can and do run both generators simultaneously at full power from the LP port on the front of the trailer (a factory feature on the 2014 EB) using a 10' CAMCO quick disconnect low pressure LP hose, a quick disconnect tee (two females and a male fitting) which I fabricated from 1/4" brass parts and the 3' hoses that came with the Propane Carbs kits.
- I was concerned that the total capacity of the LP system on the trailer might be overtaxed by the two generators. The LP port has a 25,000 BTU max sticker next to it. How many BTUs is and EU 2000? Beats me! So I ran a test. Remember this is at 80 degree Florida weather... not 20 in the Rockies... but I simultaneously ran the fridge, water heater, AC (thanks to the two Honda's) and all three burners of the stove. During the test I monitored voltage with a multimeter to see if the generators underpowered the electric system. They held 120 +/- 0.4 volts continuously.
I hope that helps.
GammaDog is offline   Reply With Quote
Old 10-30-2015, 04:26 AM   #20
Question
My bad brain got disconnected from fingers.....it's 1.5gal=6.3lbs.
eco mode.
PFC
"Tahawus"
RLC
John Prine
Old 10-30-2015, 05:34 AM   #21
65CV's Avatar
Western , Massachusetts
We've had the Yamaha 2400 for about 4 years now. We don't need to run it often and have had no issues with it. It just starts and runs. Bought the converted unit from US Carburetion.
65CV is offline   Reply With Quote
Old 10-30-2015, 05:44 AM   #22
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Originally Posted by Streamracer View Post
I use an Onan 2500 watt RV Genet that I fabricated a carrying frame and enclosed it with alum skins. I hook up to my bottles on the trailer. I have the option to run at the ac or micro. It is nice not having to go outside to start it and is also quiet. Been using it for several years. I understand the new models are self diagnostic so if you have a problem you know what it is. It is heavier and not cheap. Most don't realize that switching from gas to propane the power is derated. That being said, the 2800 watt is the same unit running on gas.
Streamracer, Do you have a thread for your trailer? I would love to see pics of how you engineered the genset housing.
mike
Bauxter is offline   Reply With Quote
Old 10-30-2015, 12:34 PM   #23
2015 28' International
Savannah , Georgia
Propane genertor
My understanding is 1 gallon of gasoline is equivalent to 1.3 gallons of propane.
sws323tt is offline   Reply With Quote
Old 10-30-2015, 01:02 PM   #24
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Do you have the version that allows you to run both gas and propane or the version that eliminates the ability to run on gas? AND are you happy w/ the version you have?
Thanks, Markr
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-30-2015, 09:59 PM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Perhaps you should consider an alternative - instead of getting a propane-powered generator and running your furnace, simply get this: http://www.amazon.com/Pro-Com-Dual-F...=procom+heater
I boondock in the desert, and the temperature drops to freezing at night. So I installed this blueflame heater. It is a convection type of heater, and heats my entire 32' AS from front to back. I do have the galley window cracked open and the vents over the stove and in the shower stall open to provide oxygen. I would add that the blueflame heater is the heater of choice among the boondockers I know.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-31-2015, 08:25 AM   #26
Tincampers's Avatar
Sneedville , Tennessee
I'd be interested in learning more about this. Could you start a new thread and show where you mounted this and how you tapped into the propane lines?
Tincampers is online now   Reply With Quote
Old 10-31-2015, 08:28 AM   #27
Tincampers's Avatar
Thanks, Markr
We have the 2400 that was converted to tri-fuel. It works great. I use only propane though as I don't want or need to carry gasoline. It always starts on the third pull and will run the hair dryer, microwave and the air conditioner. Not at the same time though!
Old 10-31-2015, 09:45 AM   #28
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
do you have the thermostatically controlled version? and if yes, w/out a power hook up, how does it "re-ignite" on it's own? or does the output just drop way low when the trailer is warmer than the set temperature? . . . or does the thermostatically controlled version need power?
thanks, markr
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
Keep Refrigerator on electric while traveling Fred2 Batteries, Univolts, Converters & Inverters 42 10-04-2015 06:33 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Turn off propane while travelling? Belbein On The Road... 27 04-28-2014 11:24 AM
