Old 08-30-2019, 07:12 AM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by HHPJ View Post
Question: propane people, do you find that you burn through a lot of propane while using for AC? Do you use a separate tank from your AS? Do you have to rejet carb at high altitudes like gas?
Thanks!
Can't answer the burn question, don't use the 2000i for AC.
I converted our Honda for dual fuel in 2007, (US Carb)
I use it for dual fuel, petrol is still more convenient when not in the AS.
It can be adjusted for altitude when running on LP.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 09-01-2019, 08:43 PM   #22
Cave Creek , Arizona
We have the Champion 3400 dual fuel but it is heavy. Champion just recently released its 2000W dual fuel- super quiet and half the weight - model 100402 - try Acne tools, seems to have the best price
Pete B55
2017 Classic
2017 F-250
Pete B55 is online now   Reply With Quote
Old 09-04-2019, 10:25 AM   #23
Half a Rivet Short
Carlisle , Pennsylvania
Thanks!
Hi
If you run your A/C on propane, you *will* go through a lot of propane. How much depends very much on how hard the A/C is working. If you are out in full sun / no breeze in Mobile and it's 99F out and (likely) 90% RH, your A/C will be working very hard all day long. Figure on going through a 20 pound bottle.
uncle_bob is online now   Reply With Quote
Old 09-04-2019, 12:14 PM   #24
Thorsondj's Avatar
2013 27' FB Classic
Tumwater , Washington
Honda 2000
I see someone already mentioned Hutch Mountain. They were a vendor at 2018 international rally at Salem. We bought kit and husband converted. Very pleased.
Thorsondj is offline   Reply With Quote
Old 09-04-2019, 12:45 PM   #25
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
If youíre camping without shore power where itís Mobile, AL, hot, thereís only one good solution: camp somewhere cooler! 🤣
Rocinante is our 2014 International Signature 27FB
Old 09-04-2019, 10:06 PM   #26
2019 22' Sport
Carlsbad , California
I have the Duromax 2000w Dual Fuel and am happy. It runs my A/C at sea level just fine, but didn’t at 6k elevation. They just released a 2200 model that likely will be enough at elevation. For the price and dual fuel capability, I’ve yet to see a better deal.
Prettygood is offline   Reply With Quote
Old 09-05-2019, 09:17 AM   #27
Half a Rivet Short
Originally Posted by Rocinante View Post
If you’re camping without shore power where it’s Mobile, AL, hot, there’s only one good solution: camp somewhere cooler! ��
Hi
No argument there, we've been out since mid July and really have not run the A/C more than two or three days the whole time. In truth the *need* to run the A/C has been near zero. We ran it yesterday simply because we could ( = on shore power). Pretty much the whole time we've been below 5,000 feet so no crazy altitude issues involved.
Old 09-05-2019, 09:26 AM   #28
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I have a Honda 2200i that I converted to duel fuel with kit from Hutch mountain. I also added an extension that runs to the propane quick connect that Airstream provides. All works very well.
I have an easystart and the generator pretty much starts the AC at full speed but will drop down to "eco" while the AC is running. Very efficient. 15,000 btu AC.
And the best thing is it is "clean"!
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 09-05-2019, 07:35 PM   #29
Woodside , California
Consider WalMart
When I purchased a used 2014 FC from a private party in Colorado I searched generator prices and comparisons. Turns out the best value I found was a dual fuel unit from WalMart. Since I couldn't purchase it online and have it delivered to California (California Air Resources Board regulations), I had it shipped to the seller in Colorado, put inside the AS, and it made the journey with the trailer. It's rated 2db louder than the Honda and was just under half the price. Easy to buy a pigtail propane hose to connect to the propane adaptor provided at the front of the AS (just inside the A-frame hitch), so generator can be placed out of the way when running. Consider how much time you will ever actually use the generator and decide if the premium price of a Honda or Yamaha is worth it.
Sportsman 2200 watt peak, inverter sine wave generator. Has output for 2 regular plugs, a 12 v outlet to connect to batteries, USB, and wired for running two generators in series.
ghanesdvm is offline   Reply With Quote
Old 09-06-2019, 11:18 AM   #30
Half a Rivet Short
Hi
The whole "how much will you use it?" *is* very much part of this. We have hauled a generator of one sort or the other on and off for three years now. Total usage time in those three years has been zero. Indeed we have a bit of solar on the roof and upgraded batteries. We also don't go "off grid" for months at a time.
Old 09-06-2019, 11:52 AM   #31
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The premium price is a courtesy to other campers. I wanted the quietest one I could find to minimize the disturbance to my neighbors and only the Honda/Yamaha fit that bill.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-06-2019, 12:03 PM   #32
Half a Rivet Short
Hi
The other subtle part of the price is how many hours the generator is designed to "live" for. After some number of running hours various bits and pieces start to wear out. It's never a hard limit, but rather a "likely to go that long" sort of thing.
On some designs, the target is around 100 hours. On other designs it may well be a lot more than that. It's not always a matter of this brand vs that brand. It's also a matter target market. If your target consumer ( = me) uses the generator zero hours in three years, a 100 hour design life may be just fine
Old 09-19-2019, 10:18 AM   #33
StephSH's Avatar
2020 23' Flying Cloud
1977 Argosy 28
Frankfort , Ohio
Champion 2000 dual fuel...
We bought the Champion 3400 dual fuel a couple years ago but the new Champion 2000 dual fuel would be sooo much easier to haul around. Has anyone tried the new Champion?
StephSH is offline   Reply With Quote
Old 09-20-2019, 11:12 AM   #34
Half a Rivet Short
Hi
At 50 pounds for a generator that will do 1440 W, it's a bit on the heavy side. You also don't have electric start. There are a *lot* of choices in the "2KW" range. Indeed dual fuel without the need to mess with a conversion kit *is* a nice thing.
Old 09-21-2019, 05:27 PM   #35
I have the 3400 dual fuel and also bought the new 2000 dual fuel. I like them both and the 2000 is super light and quiet. Its a better choice with my solar/Lithium battery setup; I rarely need a generator and only if I have canopy or rain for 7 days. Starts on 1 pull and you canít beat the built in propane option
Pete B55
2017 Classic
2017 F-250
Old 09-21-2019, 10:05 PM   #36
2007 22' International CCD
Best dual fuel suitcase style generator?
We used our 3400 dual fuel several times this last month on our epic vacation.
Ours is rigged to run off the Airstream propane tanks whilst still in the bed of the truck. Fantastic performance. The dogs enjoyed the air conditioning while we ate dinner one night.
Quiet enough to be hard to hear over the A/C fan and compressor inside the Airstream or outside over local street traffic.
Barely grunts when the compressor kicks in. Runs fine in economy mode even.
EasyStart is the next upgrade to reduce the startup Ďthumpí noise further and provide extra compressor protection.
Old 09-22-2019, 05:25 AM   #37
Long Island , New York
Larry
Bingo!
Be a good neighbor and ambassador IMO.
Old 09-29-2019, 07:21 PM   #38
GSansoucie's Avatar
2019 28' Flying Cloud
South Berwick , Maine
Dual fuel. Honda EU2200i with the Hutch Mountain Propane kit. Love ours. Goes right in front of the rig, uses the external propane line by the A-Frame and I connect it to the generator 30A port out front. Super light weight and quiet as has already been mentioned above.
GSansoucie is offline   Reply With Quote
Best 200 W portable suitcase solar setup ??? Milo1952 Electrical - Systems, Generators, Batteries & Solar 17 08-21-2018 10:38 PM
Champion Dual Fuel Generator - What do you think? trekerboy Generators & Solar Power 40 01-16-2018 11:41 PM
Champion 3400 watt dual fuel inverter-generator Milo1952 Generators & Solar Power 17 08-30-2017 12:37 PM
Champion Dual Fuel Generator SilverSinbad Generators & Solar Power 2 05-12-2017 04:48 PM
