Old 12-20-2012, 10:01 PM   #1
Best Connector tool and Connectors?
Lots of bad and ugly spade, and ring connectors on my Motorhome that need redoing.
I would like to get some advice on the best long term connectors and tools to complete the job.
I have spade connectors, both male and female, ring connecters and also splices to do.
I have a few crimping tools for terminals, the best of which is the Klein 1010..
Not really happy with the consistancy of the crimps tho.
Is there something better out there?
Old 12-20-2012, 11:14 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Solder and shrink tube. Actually the crimpers are not the problem, it's getting good, quality connectors. Solder solves the problem.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 12-20-2012, 11:18 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Another vote for solder.
Good connections that last. Definitely more work up front, but they don't need redone.
Vaughan
Old 12-20-2012, 11:19 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
A real nice crimping tool will cost about $40.
The Navy has some sweet ones. When I went to avionics school back in the 60's I got to use them a lot.And when a AK round goes thru the main wire bundle in a 46 you need good crimpers that will not cramp your hand.
I'm glad you chose an American made brand.
The good ones are still out there, try a place that sell aircraft stuff, Digikey may even sell them.
They do make a difference.
doorgunner is offline   Reply With Quote
Old 12-20-2012, 11:23 PM   #5
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
I am a retired aviation electronics (avionics) engineer and I used to be a technician in this same field. I've built and repaired a number of wire harnesses and the best tool that I have is the Dorman Products Conduct-Tite (see Dorman Products - 86595). A number of places sell this tool, including Pep Boys (see Dorman - Conduct-Tite Crimper - Ratcheting Tool | Product Details | Pep Boys). Here is an example of some crimps that I've made with this tool. I also believe in using silicon dielectric grease on wire and connections that will be exposed to weather and the elements (terminal, screw and wire end to left of center of connector have been coated in this photo as an example).
This crimp tool is about $30 and will work for red (18 to 22 gage), blue (14 and 16 gage) and yellow (8 to 12 gage) terminals. The tool ratchets and will not release until the crimp is complete. The tool is also adjustable as to how tightly it crimps. You always need to do a pull test on every wire you crimp. Put some tension on the wire with your thumb and forefinger and apply about 3 to 5 pounds of tension on the wire to make sure that it has been properly crimped.
I often use a standard crimper like the one you have in your post. I can make good crimps with that type of tool too, but it's far easier to be consistently good with a ratcheting crimp tool.
Steve
Steve Bryant is offline   Reply With Quote
Old 12-20-2012, 11:27 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, while I was in the tool business, [Mac Tools] the professional automotive electricians chose Thomas & Betts crimpers I have and use two different ones. One is for insulated connectors and the other is for bare metal connectors. Doing automotive electrical repairs at new car dealers, I have used several different types and brands; None of them compare with a Thomas & Betts crimper. Perfect crimp every time. Other brands can come loose or over crimp and break the wires.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-20-2012, 11:29 PM   #7
1991 34' Limited
Wichita , Kansas
Here is a project where I replaced the plug and the first 8 feet of the cable that goes into my tow vehicle showing the old and the new plugs. Note; I used both types of tools on this harness work.
Steve
Old 12-20-2012, 11:43 PM   #8
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Steve;
I see you're from Wichita,
you familiar with Bob Nuckolls of AeroElectric Connection?
He wrote a great handbook for EAA members a few years ago.
I call it my Avionics Bible.
The kind the Navy uses are just like the ones Robert posted a pic of above.
Old 12-20-2012, 11:51 PM   #9
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Another vote for the ratcheting style but I don't recall the brand, there are several. For terminals I prefer the marine style with heat shrink and sealant built in to the terminal instead of the std plastic insulators. They are expensive but seal to the wire very nicely.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 12-21-2012, 04:57 AM   #10
Dito, best reasonably priced crimper out there.
bkahler is online now   Reply With Quote
Old 12-21-2012, 04:59 AM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
I used to do a lot more solder and shrink wrap but have found that, for 12v automotive and rv wiring, the ratchet crimpers do a better job because the connection is just as reliable electrically and requires less space because it doesn't make the wire rigid.
I have this tool from Del City, which is only $30 and works great, even in tight places:
Open Barrel Terminal Ratchet Crimp Tool
Old 12-21-2012, 08:23 AM   #12
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
The ratcheting crimpers mentioned here are great tools.
I vote against soldering unless you really know what you are doing!
Cold solder joints, solder wicking into wiring causing it to work harden with flex and other assorted ills are easily overlooked unless you are very good.
Another source of really first class connectors and tools in Anchor brand. They are not inexpensive but they are excellent quality and if you are near a West Marine store always on the shelves. You can not go wrong!
Bruce
Bruce B is offline   Reply With Quote
Old 12-21-2012, 08:33 AM   #13
lewster's Avatar
Naples, FL , Hood River, OR
Arguably, the best, most versatile crimping tool available. I have the full set of interchangeable dies and 2 die frames and use them constantly.
CRIMP TOOL W/INTERCHANGEABLE DIES (SOLD SEP.) WAYTEK
Waytek Catalog 225
Old 12-21-2012, 09:04 AM   #14
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
IMHO this is the best option for any mobile electronics, AC or DC.
I've used these in the Automotive Repair biz for nearly 30 years. The crimpers won't over-tighten shearing wires and the self sealing heat shrink not only seals the connector but can isolate the wire end and resist any pulling or vibration.
Let's say your rewiring brake magnets. Which would you rather do? Try to get a good clean hot solder joint, hoping you didn't accidentally preshrink your tubing, or, make 2 easy crimps with a butt connector, hit the joint with your heat gun and know you've made a permanent waterproof connection.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
