03-31-2002, 11:21 AM
Administrator
1961 16' Bambi
Dallas
Best battery charger for the money?
- What battery charger do you recommend?
- Are there certain features to look for?
- Where is the best (cheapest) place to get it?
03-31-2002, 09:44 PM
Cheap and easy battery charger
Cosco and Walmart have good cheap and easy chargers. Any charger in untrained hands can destroy batteries quick. There are quite a few battery types and many different protocols for long life. Use and application are very important for the use of a charger. All chargers are not alike. Most chargers are a little bit optimistic in their charging abilities. The lowly converter is a good battery charger if it knew when to STOP charging and the rate of charge could be controlled. Application and need dictates the quality of charger. A very cheap battery charger set to the lowest charge rate and controlled by a 24 hour time clock makes a great battery maintainer. Cheap too. Charge rate is determined by battery use. Having and using a battery switch is imperative. It is great to be connected to shore power and be able to NOT charge the already fully charged battery. Frank
Visit Idaho The people are great
05-04-2002, 07:46 PM
1986 25' Sovereign
Southern Middle
I bought the BatteryMinder from www.batterymart.com for $39.95. Camping World has it for $49.95. It is a small unit that can charge 4 batteries at a time. It is a charger/desulphator/maintainer and I have mine connected to 2 Delco Voyager 105 amp hr. batteries. You can keep it connected year round without fear of it burning up your batteries. After using it for a year, I'll never buy another type unless it is an improved BatteryMinder.
Frank is right about the converter/charger. Unless it has step charging and knows when to turn off then you can destroy batteries in a heartbeat. When fully charged, the BatteryMinder does not send a charge unless it senses that the batteries have dropped some of their charge.
Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
05-04-2002, 11:43 PM
Hi David. I had those Delco Voyager batterys in my 77/31' for 10 years. Thats extrordinary! I replaced them because they were old & I didn't want a problem on the road. I replaced them with Optima yellow tops, which are deep cycle & highly recommended by several people on the Suburban BB. I would be happy to get 10 years out of them.
SF CA area
77/31' Airstream
99/Suburban/454/4.10
#18248
05-05-2002, 12:02 PM
1986 25' Sovereign
Southern Middle
Jim,
Numerous sites do not recommend the sealed maintenance batteries like the Delco Voyager but I think it is because you cannot replace fluid which evaporates from overcharging by the converter/charger in many RVs. Since I keep the Voyagers topped off with a 5 watt Solargizer/Charger/Maintainer solar panel when not plugged into the BatteryMinder, that is not a problem. I rarely connect to 110 v. so do not use the converter/charger much (Magna-Tech I think). I'm glad to see that you got 10 yrs. out of your Voyagers. I have heard if you treat them right you could expect over 6 yrs. life from them. Craig
Craig
AIR #0078
3.73 rear end
05-23-2002, 02:20 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
BatteryMinder
I just bought one of those BatteryMinders from our local Interstate Battery Distributor, for $25.95!! I am going to use in in conjunction with the converter in the trailer.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
05-23-2002, 04:16 PM
1986 25' Sovereign
Southern Middle
Pick,
Let me know how you like the system. I'm happy with mine. Also, I see you use Amsoil 0W-30 synthetic in your vehicle. I've used the Amsoil 5W-30 syn. for 8 years now and wasn't sure about making the switch to 0W-30 with my 2500HD 8.1 engine. Craig
05-23-2002, 09:03 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
Craig, I have about 8000 miles on the 0W30 now, 3000 of that a trip from Ohio to Marco Island, Fl, towing a Jeep Grand Cherokee down there one way. Truck only has 17K on it.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
10-08-2002, 11:17 AM
1971 27' Overlander
Cornville
Best Battery Charger
Pick, how are you wiring in your Battery Minder?? Will you disconnect the univolt [ Via the CB] when you use the BM?
Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
10-08-2002, 11:35 AM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
Battery minder question
I have looked at the Battery Minder on the web site listed and I have a question:
What did you do to the Univolt ????????????
Did you disconnect it completely from the battery?
Does the Battery Minder connect to the battery while the battery is still connected to the Univolt?
My problem is that the Univolt will definitely over charge the battery.
Smily
10-19-2002, 03:26 PM
1971 27' Overlander
Cornville
Battery Chargers
I viewed the BatteryMinder web site and it sounds very good, but the charge rate is only 1.2 amps!! How long would it take to recharge a battery that is at 50% discharge?? When using shore power could the BM maintain the battery at 100% if the Univolt is disconnected [Throwing the breaker]?? [To prevent overcharging the battery] That is, using the battery for 12v power and recharging overnight, via the BM??
Next question: When traveling what prevents the alternator from overcharging the house battery? I installed a disconnect switch, to prevent this in my previous trailer, may it RIP. Tom
10-19-2002, 05:48 PM
LOST
, Hawaii
Battery Minder is a maintainer not charger, it probably would take a several days to recharge a battery. But if it is sitting for months at a time it will keep the battery charged without overcharging it. If it is on a circuit with power, it will maintain the battery, univolt or not. It probably will not charge a battery overnight if it is deeply discharged.
The engine alternator has a regulator, it will not overcharge the house battery any more than it overcharges the automotive battery. If you are using an isolator it has a loss and the voltage at the batteries will be slightly lower than the alternator output.
I like my Statpower Truecharge charger (now Xantrex). They are also a float charger so they will not destroy the batteries. They are not cheap, but neither are batteries, and proper charging and maintenance is what determines their life.
John
10-20-2002, 06:05 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
Nifty, I either disconnect the batteries via the battery disconnect in the battery compartment, or the CB in the trailer, or just unplug the trailer. I am using an Exide dual purpose, that I got for cheap at Tractor Supply. Seems to work great, went two days boondocking this summer, and never got it down to 50%.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
10-20-2002, 08:47 AM
1971 27' Overlander
Cornville
Battery charging
Thanks, Pick and Argosy--After reading all the info on certain links herein, one wonders how this trailer lasted 30 years on 12v power!! I have been going to Texas and remaining one site for 2months at a time, naturally I am concerned about maintaining the batteries[without cooking them] via the Univolt. I have never had dependable 12v power in my last trailer, Then, neither did I need it. Now I do because of my new traveling mode. Tom
11-24-2002, 10:46 AM
1966 26' Overlander
Woodstock
shut off for univolt charger
to quote from earlier post-
so where/ how is the best way to put that switch in? In order to allow shore power and not continue to charge the house batteries?
My house batteries now have a ground disconnect blade on each...would that do the trick ?Thanks
11-24-2002, 12:19 PM
LOST
, Hawaii
If that is the only ground wire it will not continue to charge, but you won't be able to use the 12v battery with it open either.
John
11-24-2002, 12:34 PM
2001 34' Limited
The State of
I sure wish I had enough justification to replace my Magnetek converter with a 55-amp Inteli-Power with Charge Wizard. With higher boost voltage, it can charge a lot faster and with lower float voltage, it won't use as much water in long-term storage. I also like the Equalize mode every so often.
Of course this assumes the parked trailer has access to 120VAC and the batteries aren't being removed from the trailer.
Maurice
11-24-2002, 12:59 PM
Just a member
1978 28' Argosy 28
Lutz
Alan,
You might want to see if your MH is set up like mine. I have a single breaker that runs only the univolt. I use it like an on/off switch to controll the charge and noise. If you don't have that as an option, you could get a multioutlet power strip and use it between the univolt and the wall outlet it is plugged into. Then you could use the switch on the power strip for control.
I also have Ground disconnect switches on both batteries so when I store I can disconnect quickly to eliminate all drains on the batteries.
BTW even with my controlling of the charge and not leaving the univolt on all of the time I cooked my 8 month old coach battery dry. I checked prior to going to the shuttle launch and it was almost dry. Filled it up and used it, but it is weak. I will see if I can bring it back to life, but I doubt it. I have to remove my engine battery to get to the coach battery and both of them are a bear to take out. Checking once a month is a great plan, but it takes an hour!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
11-25-2002, 07:18 AM
1966 26' Overlander
Woodstock
thanks guys for the info.
So if you shut off the univolt, can you still acess shore power for the outlets, etc?
I thought the univolt not only charged but also managed the ac coming in, and converted to 12v for the outlets where needed.
am I confused?
My coach batteries registered 11.9 yesterday after staying on my little 10amp charger quite awhile individually. They came up further after I ran my generator for an hour or so, but I do think they are fried. The little green eye is still there, but they don't want to hold a full charge. My univolt was putting out 13.6v, when I disconnected the batts to check it.
11-25-2002, 11:24 AM
LOST
, Hawaii
Alan-
Is that the same charger you posted about that was only putting out 2v? Did you check the voltage with it on the battery? Maybe it is shot, will put out good volts until you load it, but won't put out under load. Thinking this because the univolt charged your batteries when the charger wouldn't.
If the univolt is off, you are running 12v circuits off the battery, but should still have 120v in the other circuits as long as you have shore power and the breakers are on.
John
