Old 02-06-2015, 09:55 AM   #15
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Originally Posted by dznf0g View Post
Nice! I bet they'll make more.
Sure they'll make more, but that one was yours... Man, I feel bad, but there's nothing to be done about it now.
-Red, being purposely obtuse...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-06-2015, 10:52 AM   #16
dznf0g's Avatar
Oswego , Illinois
geez, ya learn something new about people every day!
-Rich-
Old 02-06-2015, 11:17 AM   #17
Panama Red's Avatar
Obrien , Florida
Tell you what, since I drank yours, my cooler will be open for you at Canopener 2016... it's the least I can do. Literally...
-Red, making amends with limited liability...
Old 02-06-2015, 11:19 AM   #18
dznf0g's Avatar
Oswego , Illinois
Wish I could be there.....Save it and you can have it then....but not till then!
-Rich-
Old 02-06-2015, 11:22 AM   #19
Panama Red's Avatar
Obrien , Florida
Man! Thanks! Not everybody would so willingly give up their beer like that...
Sorry for the thread hijack. I'll quit now.
-Red, sensing skunky beer in his distant future...
Old 02-06-2015, 11:40 AM   #20
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The wire size is important for longer distances due to voltage drop caused by internal resistance of the wire. An analogy is a ¼" water hose out 25 feet and a ⅝" water hose out 25 feet. Obviously the larger hose delivers more volume but at also closer to input water pressure (volts) as compared to the pressure drop in the small diameter hose.
In a perfect world, the wires from the batteries to the inverter should be adequate sized per the National Electric Code for the inrush current imposed be an device with a motor. Resistive loads like a toaster are constant power draw from turn on to turn off.
There are usually only 15 amp rated 120Vac outlets in a trailer, the factory #12 wire is rated 20 amps and is usually on a 20 amp breaker, so that reduces the voltage drop and allows for more devices to run at the same time (up to 20 amps momentary use, but that #12 wire is rated by the NEC for 16 amps continuous load).
We have a 400 amp fuse between our battery bank and the Magnum MS-2812 inverter/charger that is capable of creating 2,800 watts of AC power (can even start and run the rear air conditioner for awhile). The wire size is 2-0 copper or about the diameter of my thumb.
That is why all inverter installation manuals prefer the shortest possible wire runs of larger wire size from the battery bank to the inverter.
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Wire gauge from Battery to Converter Sairaf Batteries, Univolts, Converters & Inverters 9 01-07-2013 08:39 PM
How long can my battery cable be - and what gauge wire? robwok Electrical - Systems, Generators, Batteries & Solar 3 10-20-2011 09:52 AM
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 12:24 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
