Old 12-19-2015, 02:34 PM   #15
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I bought a digital volt meter from Amazon that plugs into the 12v recepticle (cigarette lighter). I can instantly check my voltage. It I switch it to store with shoe pwr. It goes blank. Quick & simple.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 12-19-2015, 02:37 PM   #16
2016 25' International
Upper Arlington , Ohio
Thank you Drathaar. Battery Tender it is.
Brad Waite
2016 25FB International Serenity
bwaite is offline   Reply With Quote
Old 12-19-2015, 02:52 PM   #17
1973 31' Sovereign
Middletown , California
Just so people know, the cheapo battery tender from Harbor Freight will over charge your battery in storage. I tried 2 of them and both were not shutting off. As far as the lack of charge on shore power, I'd suspect the contacts in the relay. It usually helps to toggel or flip the switch of electrical things when troubleshooting, as well as giving it a few good "thumps" to see if there are some questionable connections moving around. A bad connection will run hot so that can be a clue. I like to start any troubleshooting with a factory wiring diagram if you can get one or often I draw my own as I go to help me understand exactly how the current flows. Use caution not to short anything when poking around as there is a lot of current available in a battery. This should be a simple fix. Leland
ijustlee is offline   Reply With Quote
Old 12-19-2015, 08:43 PM   #18
cuyeda's Avatar
Long Beach , California
Yes, on everything suggested so far. I find that if the battery drains completely, the relay tends not to function. It needs some type of voltage source to the battery enough to engage the relay circuit. If the battery charges with the tow vehicle connected, then you shouldn't have a problem after, because the relay should get energized then.
Also, check the relay, there are fuses on each contact lead.
However, if your battery is not holding a charge that will be another issue.
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 12-20-2015, 12:24 AM   #19
2007 22' International CCD
Yup. The control relay that connects the battery won't work unless there is enough charge on the battery. That's why my solar system is hard wired to always charge the batteries.
KE4GNK/AE
Battery Good No DC Power with shore power off. Frank Ross Batteries, Univolts, Converters & Inverters 15 08-09-2014 03:42 PM
Battery doesn't charge without disconnect / reconnect of shore power WineStream Batteries, Univolts, Converters & Inverters 5 03-26-2013 06:32 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
