Old 04-19-2006, 08:00 PM   #15
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
See the battery install photos
Yeah Pick, I think I figured out how to direct someone to my few little photos. If you left click on my forum name (at the left of my message) it will unfurl a set of menu choices, one of which is to view my pictures. I tried to explain how I built the rack and hold-downs in the captions. Not a great place to take pictures since I built this from under the bed platform instead of removing the plywood mattress platform. Worked out great. For now I check the battery reading with battery d/c'd from shore power and only phantom loads on it by reading at the post jack power wire (I remove the fuse and read the hot side to chassis).
DreamStreamr is offline   Reply With Quote
Old 04-19-2006, 08:06 PM   #16
Fuil-Timers
Images: 38
Generator to charge battery
Bob,
We bought a really nice 1kw Yamaha gasoline generator last year. Haven't needed it, might never. (darn it!) Very slow charge rate and not much power but should do great in a pinch. Coolest thing is how light (27 #) and how quiet (47 dB) and how gas-stingy (runs forever on 1 gallon). Really figure it is for when we start full-timing. Each thing we shop for has to meet the dual-purpose test -- cannot afford to carry very many single-purpose things, just like when we are backpacking.
Sorry to miss you guys at Galax. For any other readers who could go, Old Time Fiddlers Convention in Galax VA is one excellent outing and a wonderful rally. Great weather, phenom music, and tremendous collection of oddball campers in the infield. We loved it and would encourage anyone to try it.
Later,
Old 04-19-2006, 08:16 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Over59
Please explain this in terms of spec reading. Do I understand you to say two 220 amp 6 volts with give up more juice than two 110 amp 12 volt or one 220 amp 12 volt?
http://www.lifelinebatteries.com/rvbatteries.php
The specs from the lifeline web site:
Gp 24.............................80 Amp-hours.......................149 min. discharge
Gp 27............................100................. .....................189
4-C 6-volt......................220..................... .................492
4-D...............................210............... .......................390
8-D...............................255............... .......................475
As you can see, the 6V golf cart battery, using 2 in series, will give you more amp-hours and WAY more discharge capacity than any 2-GP 24 or Gp 27 combo and even more than the behemoth 4-D or 8-D batteries. Plus, they have much thicker plates and are rated for more charge/discharge cycles.
Remember, you add only the voltage when connecting in series (2 X 6+12V) but you add the amps when connecting in parallel (2 X 12= 12V) but double the amps. The 4-C's win either way!!!! This is why most major MoHo OEM's have switched the house batteries on the bugbusses to 6V combinations and don't use 4-D or 8-D any more.
Old 04-19-2006, 08:41 PM   #18
Fuil-Timers
Images: 38
discharge rate and amp hour rating
The only advantage the 6v batteries provide is first cost. One 12v AGM weighs about the same, takes up about the same space, doesn't gas, won't leak, has greater discharge capacity (504 minutes) and higher amp hour rating (258 @ 24 hr rate) than two 6 volts. http://www.bitterrootsolar.com/battery/concorde.htm
Very expensive, $400 for Concorde PVX2580L, but longer life rating, trouble free, different shape may work better in some applications, same very thick plates as Trojans. I guess it really amounts to different strokes for different needs, eh?
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
Old 04-19-2006, 08:48 PM   #19
Images: 59
Lew,
Your numbers are right as far as they go, but keep in mind that the amp-hours and the minutes at 25 amps are at 6 volts for the 4C.
The 4C battery will put out 6V*25a=150Va for 492 minutes, whereas the 4D puts out 12V*25a=300Va for 390 minutes.
Without making adjustments for Peukert factor, the 4C is probably only good for 240 minutes at the same energy output level (Volt-amps) as the 4D battery.
Old 04-20-2006, 05:21 AM   #20
lewster's Avatar
Mark,
When you use 2-6Volts in series you should get about the full amp draw rating.
Dreamstreamr,
The 4-C golf cart batteries I was suggesting IS an AGM from Lifeline, so no gasing or other issues....just to clarify
Old 04-20-2006, 05:58 AM   #21
Images: 59
Originally Posted by lewster
Mark,
Thats correct. I just want to point out, in the context of this thread, that you need to double the weight of batteries in order to achieve that.
Old 04-20-2006, 05:58 AM   #22
Fuil-Timers
Images: 38
Whoops!
Lew,
My apologies. Also my point about AGM only half matters, in a way -- unless someone is installing inside the cabin the non-venting requirement of the AGMs just doesn't matter. The true maintenance-free aspect of AGMs only matters for dummies like me who didn't keep their plates covered with water. I like the double 6v solution, have seen it on several members' outfits. Certainly more cost effective on front cost and probably lifecycle cost too.
Sorry about that -- I knew I was getting out of my league on this thing anyway and sure enough can real quick end up talking about more than I know. I realized after I sent I was being a little (too) enthusiastic about my new battery. I appreciate your kind correction.
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 04-20-2006, 07:58 AM   #23
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
One advantage to two 6V golf cart batteries in series, compared to two 12V batteries in parallel, is in discharge cycle life. You can either discharge them deeper for the same number of discharges, or discharge them more times for the same depth of discharge.
Another advantage is that while they may not have significantly higher capacity (220AH vs 200AH) at the low discharge rates typically used when boondocking (i.e. 10A or less), they ARE significantly better at high discharge rates, such as the 25A rate used to establish "Reserve Capacity," or even higher, such as you'd find with heavy inverter usage. Keep in mind, though, that you have to compare their 25A rating to a 12.5A rate through each of the 12V batteries in parallel. Here's the calculations of Peukert Exponent (n) and Peukert Capacity (Cp) for the Group 27 and Group 4C Lifelines. Note that there isn't much difference in 2 x the Cp of the 12 volt batteries compared to the Cp of the 6 volt batteries, which indicates there will be little difference in their capacities at low current draws. But watch what that huge difference in exponent does as the current draw goes up. I've calculated the time for a 10A total draw (the 20 hour rate of the two 12V batteries), a 25A total draw (the standard for establishing "Reserve Capacity", and a 100A and 200A total draws, powering a 1000W and 2000W inverter, for example:
Group 27
(logT2 - logT1) / (logI1 - logI2) = n
(log186 - log1200) / log5 - log25) = n
n = 1.1583734592428565078682881631963
Cp = (5A^1.1583734592428565078682881631963) x 20 hours
Cp = 129.03225806451612903225806451613
Cp/I^n = Time so for 10A load, 10A/2 = 5A per battery:
129.03225806451612903225806451613/5^1.1583734592428565078682881631963
= 20 hours
Cp/I^n = Time so for 25A load 25A/2 = 12.5A per battery:
129.03225806451612903225806451613/12.5^1.1583734592428565078682881631963
= 6.9 hours (415 minutes)
Cp/I^n = Time so for 100A load, 100A/2 = 50A per battery:
129.03225806451612903225806451613/50^1.1583734592428565078682881631963
= 1.4 hours (83 minutes)
Cp/I^n = Time so for 200A load, 200A/2 = 100A per battery:
129.03225806451612903225806451613/100^1.1583734592428565078682881631963
= 0.62 hours (37 minutes)
Group 4C
(log492 - log1200) / (log11 - log25) = n
n = 1.0860161267351761034826747166678
Cp = (11^1.0860161267351761034826747166678) x 20 hours
Cp = 270.39536696992743815972924455649
Cp/I^n = Time so for 10A load:
270.39536696992743815972924455649/10^1.0860161267351761034826747166678
= 22.2 hours (11% better)
Cp/I^n = Time, so for 25A load:
270.39536696992743815972924455649/25^1.0860161267351761034826747166678
= 8.2 hours (492 minutes) (19% better)
Cp/I^n = Time so for 100A load:
270.39536696992743815972924455649/100^1.0860161267351761034826747166678
= 1.8 hours (109 minutes) (31% better)
Cp/I^n = Time so for 200A load:
270.39536696992743815972924455649/200^1.0860161267351761034826747166678
= 0.86 hours (51.4 minutes) (38% better)
Finally, there's a major difference in the failure modes of two 12V batteries in parallel vs two (only) 6V batteries in series.
If a cell opens in the 12V setup, you just continue to operate at 50% capacity. If a cell shorts in the 12V setup, the shorted battery discharges the good battery, but you can disconnect the bad battery, recharge the good one, and continue to operate at 50% capacity.
If a cell opens in the 6V setup, the whole system is dead. Period. If a cell shorts in the 6V setup, voltage drops to that of a dead 12V battery, even if all the other cells are fully charged. So essentially, the system is dead.
It may not make much difference boondocking in an RV, where you can hook up and head home, but if it happens a few days offshore and you don't have fuel to motor (and power your electronics) all the way home, it's more serious. That's why most boaters that go the 6V battery route have more than one pair of 6V batteries. The same is true for the big motorcoaches. There's been a bit of a trend away from the big 4D & 8D batteries in both, mainly because of the difficulty swapping them out, if required. It's about like swapping out a small diesel engine.
Finally, where space is concerned, there are differences. The 6 volt batteries have a smaller footprint, but are taller. Depending on your space available, one or the other setup may be better for that.
Maurice
Old 04-20-2006, 10:00 AM   #24
Images: 59
Maurice,
I am impressed. I agree with your conclusions. I do need to critique the numbers, however.
If you 'backtest' the numbers in the Lifetime chart, there are some glaring consistencies in the data.
I calculated the Peukert coefficient for all the batteries in the list, but I used the 8/15/25 amp discharge minutes, instead of the 25a and 20 hr rates.
The resulting numbers were about what I expected. The Peukert coefficient has some 'drift' as you go from low to high discharge rates.
However, the Peukert coefficient for the 6V (4C) battery was exactly the same for all three calculations. Too much the same. So much the same that I believe the numbers were calculated rather than based on test data.
So I guess I'm saying I agree with you, but don't have any faith in the numbers published by Lifeline for the 4C battery.
"I reject your reality, and substitute my own!"
Old 04-20-2006, 10:25 AM   #25
2001 34' Limited
The State of , Ohio
Mark, I've always used the 20-hour amp-hour and reserve capacity ratings to calculate the Peukert exponent and capacity, but I did do these in a real hurry this morning, copying and pasting from the Windows calculator, so I could've made a mistake.
I wasn't going to say anything, but the Lifeline numbers for the 4C looked a little suspicious to me also.
Maurice
Old 04-20-2006, 10:36 AM   #26
Images: 59
Originally Posted by RoadKingMoe
Mark, I've always used the amp-hour and reserve capacity ratings to calculate the Peukert exponent and capacity, but I did do these in a real hurry this morning, copying and pasting from the Windows calculator, so I could've made a mistake.
Maurice,
You did the calculations right. I was using a totally different method as a way to check for data integrity. When I found the data was 'too good' for the 4C battery, I had to call it out.
As you know, the Peukert coefficient is a part of an equation that represents the non-linear behaviour of a battery under different load conditions. If you calculate the Peukert coefficient at different discharge rates, the coefficient should be different. If it is different for all the batteries except one, and that one is remarkably constant, then I can only conclude that the numbers were 'worked backwards' by the person who wrote the chart.
Old 04-20-2006, 11:06 AM   #27
2001 34' Limited
The State of , Ohio
What hoisted the BS flag on it for me is that AGMs usually have just slightly less capacity than the best similarly sized Trojan flooded cells, and that's true for the other Lifeline batteries I've looked at (and use). However, Lifeline's claims for the 4C are much greater than the specs of the Trojan T-105 6V flooded cell. Something's fishy here. Nevertheless, I used Lifeline's specs for it in my calculations above. Maybe it does perform as claimed, but I'm suspicious.
Maurice
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
