Old 04-20-2009, 08:15 PM   #1
1982 28' Airstream 280
Buena Park , California
Battery, Solenoid, Isolator Setup
My motorhome is setup differently than the manual describes. Is there a reason why the PO would have chose to set it up this way? Should I hook them up according to the manual?
The red text is the way the system is setup currently.
kennytheecat is offline   Reply With Quote
Old 04-21-2009, 06:22 PM   #2
bump
Old 04-21-2009, 08:00 PM   #3
Images: 59
That would be a good starting point.
Whoever wired the spotlight to the alternator tap on the isolator didn't have a clue what was going on, so starting over is a good idea.
Old 04-23-2009, 08:14 PM   #4
Harry P
1995 36' Classic 36
Elk Grove Village , Illinois
I often find that if the system is working, it is probably connected properly. I have been working hard on a problem in my 95 Classic MH that is not charging the batteries enough.
In the process, I have learned a bit about isolators. (by the way, the top photo/schematic is not an isolator, it is a relay/solenoid). The bottom is an isolator. I have found a few web sites that discuss connections on isolators, one of them is at www.surepower.com/pdf/180012q.pdf. If you want the main web site, it is Sure Power Industries.
The trick for me, and perhaps for you is to figure out all the various wires connected to the solenoids and isolator. My AS schematics are very vague and leave me with more questions than answers, and hours of tracing near impossible wiring.
HP
harryp is offline   Reply With Quote
Old 04-23-2009, 08:45 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
It looks as if the isolater in now mis used. The solenoid, as advertised, just adds the third battery for starting. Alternator should go to middle isolator post, one main battery on either end. As wired, the spotlight will only work with the engine running.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
battery solenoid mystery Airstr345LE Batteries, Univolts, Converters & Inverters 8 03-22-2009 12:00 AM
Battery Solenoid ??? jisom12 Batteries, Univolts, Converters & Inverters 8 04-18-2008 02:45 PM
Need battery isolator for my TV? ldetsf Tow Vehicles 3 11-11-2006 02:27 PM
Battery Isolator wa3vez Mechanics Corner - Engines, Transmission & More... 5 09-02-2004 12:27 PM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
