Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-23-2002, 05:15 PM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Exclamation Battery Slide Out
Has anyone installed a battery slide out shelf in there battery compartment. The battery in my '71 Int, is located in the rear compartment. Home depot sells slide brackets that support 100#. The battery is a bear to work on. Would help! Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 12-30-2002, 10:17 AM   #2
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Question Supports for slides
I have the same AS..........
and the same problem. I am wondering how you would mount the slides?
My battery is "sitting" on a wooden frame that straddles the plumbing lines. The base of the vanity is behind the battery. The vanity is certainly not stout enough to support the battery especially extended on slides.
This one is up for consideration. Anyone with rear compartment and battery stowed in this location, please shoot some ideas and lets see what we can come up with.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 12-30-2002, 10:35 AM   #3
74Argosy24MH
Profile:  LOST , Hawaii
How about an angle iron frame to straddle the plumbing? It would have to be lagged to the floor to support the weight when extended. You also need to make some type of latch to hold the battery in when moving.
John
74Argosy24MH is offline   Reply With Quote
Old 12-30-2002, 12:45 PM   #4
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Swing out tray
How about a tray mounted on a frame that stradles the plumbing (John) and has a pivot point to swing the battery out of the compartment for maintenance. This is a photo of my 1968 stock tray after I coated it with POR 15. You can see the retaining pin on the left rear and the pivot stud on the right.
Randy
Old 01-01-2003, 02:58 PM   #5
niftypkg
niftypkg's Avatar
Cornville , Arizona
Slide out Batt. tray
Randy. I have the exact same tray in my 71' Int. So the battery tray pivots on that bolt, so what?? That bolt will not support the battery. What is it for???????? Tom
Old 01-01-2003, 03:41 PM   #6
68 Overlander
Commercial Vendor
Images: 21
Tom,
While it's true you can't support the battery on the bolt if you rotate it 90 degrees, I just swing it about 60-70 degrees to check the water level, etc and there is enough support for that as the weight is still on the platform and the frame for the access door. As for what is if "for", who knows but that's what I use it for. I was really just offering the idea since you are thinking of building something. I agree that having it slide all the way out would be ideal.
Randy
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 05:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
