Old 01-22-2017, 05:04 PM   #1
2012 Interstate Coach
Wayne , Nebraska
Battery replacement
Have a 2012 Interstate, one bad house battery should I replace both?
Also suggestions on replacement for Triplite inverter.
Ron
Ron W is offline   Reply With Quote
Old 01-22-2017, 06:44 PM   #2
1977 Argosy 28
Fallon , Nevada
Exclamation Always replace both batteries
Welcome Ron,
It doesn't matter if it's a flashlight or an RV, if it has two or more, replace them all.
As for your question about replacing the Tripplite, that's outside my knowledge but the Forum has lots of threads on the subject; check them out. The gist is, replace the Tripplite with the newer, more capable Magnum. It's quite possible the Tripplite's high float voltage fried your batteries.
All the best, Dave the Scourge of the ION
Scorge-ION is offline   Reply With Quote
Old 01-22-2017, 08:07 PM   #3
Wayne , Nebraska
Thanks Dave! Any recommendations on what to use?
Old 01-22-2017, 08:49 PM   #4
Naples , Florida
Yep! 2 new Lifelines and a Magnum MMS-1012 1000 watt sine wave inverter/charger with temperature sensor and their ME-RC programmable controller will solve your battery problems.
lewster
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 08:36 AM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
