Old 01-13-2005, 05:15 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Battery replacement?
Should I buy same? My tt came with Interstate SRM -27 s Should I go for Optima? AGM? Should I replace with the same?
I am going to get solar chargers for the new ones; I am a little tired of this battery operation in my garage.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 01-13-2005, 06:58 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Itsa personal choice
The Battery industry offers lots of choices, and you should get lots of advice and shared feelings...
I believe brand is a guide, and some are better than others, and Intersate is good.. Some of the other factors to consider in defining good value for price to be paid:
1. Should be Marine/Deep Cycle type, rather than automotive.. Mode number or group type defines physical size and config, so Group 27 is large unit with top terminals, and that should be replicated..
2. Several makers now offer gel cell instead of wet cell (wet = acid) that claim to offer longer life and lower risk of acid spills.. Price is higher, but if you search this site looking for battery or batteries you'll read others' opinions...
3. Within Group and physical size, you get variations in ratings (Amp Hours and CCR (Cold Cranking Rating).. The higher the numbers the more electrical reserve capacity built in the battery..
4. Finally, makeers offer different warranty terms (kinda like mattresses) which are almost coded versiosn of quality ratings.. They may run from 60 months to 84 or 96 months, and some ofer periods of free replacement followed by periods of "pro-rated replacement" where you can get discounted price from same mfr for new model of theirs...
5. Be willing to deal with local and reputable source, but could range from big discount center to local mechanic/dealer. Reason is that more than trivial percentage of batteries do have mfg defects, dead cells, etc that require return or exchange or service call...
I've concluded that good deal for me (and we have pair of new Group 27's) is lowest price for at least 84 month version with high-end Amp Hour rating... Price for Exides or Die Hards or Interstate wet cell should be around $90, but could vary widely, depending on sales, etc... I did set-up and installs, but you may wish to find someone who can do it for you, as they are VERY heavy, and compartment is tight with potential for spectacular sparking contact with shell and fuse issues or acid leaks if mis-handled...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-13-2005, 07:46 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Kistler!
Have you considered purchasing the batteries as part of your solar package install? I had AJL Solar include AGM batteries with my solar package (on '64 Overlander), and the installation has been a success for my purposes. The solar panels have kept the batteries uniformly charged, and the batteries show no signs of wearing out after more than four seasons.
For my Minuet where I don't have the solar to depend upon, I usually watch the sales and purchase a new DieHard RV Marine Deep Cycle battery - - since the Magnatek converter in that coach has a tendency to boil the electrolyte, I count my self lucky if I get more than a season from a battery.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 01-13-2005, 08:28 PM   #4
Consider switching from 12V batteries to 6V batteries (if you already have two batteries). This way you can almost double your amp capacity at less cost and get deep cycle batteries.
I will do this when my 12V batteries die.
And I just installed solar and next month will be installing a Wave 6 catalytic heater.
Neil Ervin
neil.ervin is offline   Reply With Quote
Old 01-14-2005, 05:36 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
fyi- I am a bit disappointed in my Optima yellow top. The first one I got died quickly ( had a short in it)and the replacement I have had for 6 or 7 months, does not hold its voltage as well as my Autozone special ,that I use for the engine.
I have to keep checking it. The ground is blade switch disconnected, so it surprises me that it drops in voltage.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-14-2005, 06:06 AM   #6
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Optima yellow top
That's interesting, Alan. My Caravel is undergoing major renovation now, and my refurbisher recommended the Optima batteries.
A big advantage touted of the Optima is that they can be placed in any location, in any orientation, since they are sealed and don't outgas hydrogen. This is handy in the tight spaces of the Caravel, since I might want to install two batteries and I don't have traditional space for it.
We are ditching the Univolt and replacing with an Intellicharger with charge wizard, so boiling the batteries is not such a concern as it was before.
Anyone else have experience with Optima besides ALANSD and overlander64? They are expensive per amp-hour compared to regular batteries and I'd like to be more confident about buying a pair of them -- or find a better choice.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 01-14-2005, 06:13 AM   #7
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
i was in sams club the other day. the interstate grp 27 was priced at $71..
the optima(yes i didnt check specs, just price), was $141...when its time to replace, i bet you can guess which one they will be replaced with....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 01-14-2005, 03:52 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i was at my local battery supplier the other day getting new batts for my diesel plow truck and asked the guy about optimas.
all he said was "look over there" pointing at the scrap pile, about half of them were optimas. red, blue, yellow... 'nuff said in my book.
at least they honor the warranty.
i prefer marine starting bateries. they work well with the univolt and charge at the same rate as the two in my truck. they are inexpensive as well.
john
you call them ferrets, i call them weasels.
Old 01-14-2005, 04:39 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I am also upgrading the Caravel to an intellipower and would like to switch to a sealed battery so I can stow it in a bit of otherwise unusable space under the gaucho. If I don't do this then I will have to get a battery box and vent the battery, which hasn't been vented for a long time, although it should have been, since it's under the bed!
Why are two 6v batteries better than one 12v? How would you hook them up, in series?
Rich, how are you going to squeeze two batteries in there? There's not much room.
Stephanie
Old 01-14-2005, 06:11 PM   #10
greg176's Avatar
Gabriola Island , British Columbia
For good info on batteries go to www.phrannie.org and read the battery poop sheets.I will be using two 6 volt trojans in a vented box under the front dinette.
greg176 is offline   Reply With Quote
Old 01-14-2005, 06:17 PM   #11
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
done the battery thing and i now have sams club batterys. "junk" sams doesnt have interstate here. my next set will be interstate size gp 27 rv batteries. had interstate before and i still wander why i switched to brand x. i have already replaced the brand x batteries with sams brand x . the first set didnt last a year. i have the charge wizard so i didnt boil them. the present set is working a lot better than the other set.
the optima had a drastic drop in amp hour rating . compared to other gp 27 batteries. i just couldnt juimp on them for the money. guess i will ride the sams club batterys untill the warranty runs out. i looked for 6v. they will not fit in my drawer they are too tall . arcie sparkie and maybe blow up in the drawer. not good..
go "interstate" is my recommendation.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 01-14-2005, 08:30 PM   #12
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Stef, we measured and found we could fit one Optima in the traditional battery space and another in the bathroom closet just a couple of feet back. I didn't want to give up any more of the battery compartment because that's the only utility space in the Caravel for hoses, levelling blocks, etc.
The Optima gave me flexibility to put the battery anywhere without worries about venting. But with all the negatives about the Optima here, I am re-considering it. It's twice the price per amp-hour apparently.
Old 01-17-2005, 02:43 PM   #13
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings rluhr!
I couldn't remember which of the AGM batteries that AJL Solar installed in my coach so I took a photo of one of the three when I was checking on the coach this afternoon. The photo is below. More information and specifications on these batteries can be found at:
Sun X Tender Deep Cycle AGM Battery (Scroll to Middle of Page)
Concorde Battery Sun X Tender Deep Cycle Battery Specifications
These batteries have truly met every one of my expectations - - trouble-free, maintenance-free, and plety of reserve power. I believe that the batteries installed in my coach are quite similar to the current model: PVX 1040T.
Good luck with your investigation!
Kevin
Name:	Sun X Tender Battery.jpg
Kevin D. Allen
AIR #827
Old 01-17-2005, 03:12 PM   #14
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Being somewhat new to actually enjoying the Airstream I spent eight months refurbishing, I opted to purchase whatever battery my white box RV dealership had on the floor (no A/S dealership here).
I reasoned that we would not be doing any real camping without hookups until we were comfortable with being in the Overlander for a reasonable amount of time. I only needed a battery to power the brakes in case of worst case scenario & to find the bathroom at night while we were on the road.
I did good because the run-of-the-mill battery I bought has already inadvertently been run down to nothing twice though operator error. Although it charged back up, everything I have read leads me to believe it is now not capable of what it was designed to do.
My point is: keep in mind what you plan to do with your Airstream when deciding how much money to spend on a battery. If your plans are full hookups, choose wisely.
Tom
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
What tires to replace with? Charcigar Tires 1 04-09-2002 01:08 PM
