Old 07-17-2016, 10:41 AM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
Battery recharging questions
We are dry camping in Salt Point State Park on the California coast and I had some questions about our battery charge because this is the first time we will have been without electrical hookups for so long (it'll be a least a week and a half before we get out of here….).
Our AS, a 25-foot 2004 Safari has two solar panels hooked up to a Heliotrope HPV-22B recharging system. We are using the batteries very minimally, mostly for quick showers, but also for some lighting during cooking. The system starts charging as soon as it gets light outside and continues until it gets dark. The charge level never dips below 12 volts (reading 12.51 right now at 8:15 a.m. when it's overcast and nothing electric is turned on except for the fridge). We are going into our third full day here without using an outside electric source. Later today I'm going to hook up the Honda EU2000i generator for two hours of charging for the laptop and some other non-trailer items. But in the meantime I was wondering how long we could go using just the solar panels? If they keep the charge into the 12 volt plus range is that enough, or should I supplement the charging with the generator every two days or so (which is what I did on an earlier dry camping trip)? Also, I'd like to maybe use the furnace occasionally as the temps are rarely getting above the 50s. Is the furnace fan a huge draw on the electrical reserves?
Any suggestions would be welcomed! I'll check back on this thread in the mornings and evenings when I go to the ranger station to use their wifi.
Thanks in advance! This forum is a great resource which I've already used many times to answer questions I've had as a complete AS newbie (this is only our sixth outing)!
StreaminGeo is offline   Reply With Quote
Old 07-17-2016, 11:19 AM   #2
mandolindave's Avatar
You sound good to go
#1 You have solar
#2 You have a Jenny
#3 You are conserving power.
Yes, your furnace blower is your biggest draw. You could heat up the trailer before you go to bed, then turn it off. Or turn it to the lowest temp that you stand. The furnace can almost wear down your batts in one night, especially if you start off not topped off.
Too late now but sleeping bags are a good solution.
mandolindave is offline   Reply With Quote
Old 07-19-2016, 04:44 PM   #3
2004 25' Safari
Can I go with the solar panels alone or should I boost every few days with the generator?
Old 07-19-2016, 04:52 PM   #4
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
At 12.5 volts you are about 90% charged. 12.0 volts is considered empty. I have solar panels and don't own a generator. Google "battery voltage charge chart". I'd skip the generator unless your batteries begin to approach 12.0 volts.
kscherzi is offline   Reply With Quote
Old 07-19-2016, 04:52 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Only you can determine that based on your usage and solar charging rate. I recently spent two weeks dry camping on the Blue Ridge Parkway. The solar was almost useless due to well shaded campsites. I ran my propane converted Yamaha 2000 several times for two hours late in the afternoon. With the small input from my 100 watt panel that kept my batteries up to safe levels.
MICHAEL
Old 07-19-2016, 04:56 PM   #6
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
as a side note:: if you have good sun during the day on the solar panels and they are big enough, ie 2-225 amp hr batteries = 450ish watts of solar needed, and if the system is setup correctly, and if the wires are LARGE enough, then you should NOT need a generator.
check out handy bob solar at https://handybobsolar.wordpress.com/...andybob-solar/
read, read, read and then read it again. all you want to know about solar from some who is a FULL time solar user.
good luck and happy trails.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 07-19-2016, 04:58 PM   #7
Long Island , New York
This chart gives a rough overview:
http://www.marxrv.com/12volt/voltchart1.gif
We always try to keep the batteries above 12.5 if possible, and definitely above 12. The chart linked above is on this page:
http://www.marxrv.com/12volt/12volt.htm
Good luck!
Peter
Old 07-19-2016, 05:13 PM   #8
AWCHIEF's Avatar
Images: 33
Peter, excellant resource, thank you
MICHAEL
Old 07-21-2016, 09:52 AM   #9
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Good luck!
Peter
Awesome info...THANKS!
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Why is my battery not recharging when towing? drrob Batteries, Univolts, Converters & Inverters 11 09-10-2015 06:07 AM
Odd noise from Battery Compartment? Solar recharging? 02interstate Sprinter and B-van Forum 6 05-28-2015 12:48 PM
Recharging battery with Parallax converter/charger Goal15 Batteries, Univolts, Converters & Inverters 10 10-18-2011 05:37 PM
Recharging Armstrong AC jfremstad Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-27-2008 11:26 AM
Recharging A/C LowellN Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-09-2005 10:28 PM
