Old 04-01-2015, 01:29 PM   #1
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Battery question/advice
I was reading an article in a trailer magazine about batteries and toward the end the author stated in passing: "you can run AGM batteries below 50%".
I have read many articles and threads on this forum and it has always been gospel to never run batteries below 50%. Did I miss something or was this writer throwing out something that was in his head but not true.
I know a bit about wet batteries, but almost nothing about AGM's - which I bought two years ago (2x6v) and am very happy with - but it would be great to get more use out of them, and/or not get so worried when I'm running down close to 50%.
Any knowledge out there about this?
Thanks, you'all
Silver Hawk is offline   Reply With Quote
Old 04-01-2015, 01:49 PM   #2
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Sure you "can", but should you? Not routinely and as infrequently as possible.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 04-01-2015, 01:50 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Much folklore and little fact
AGM or wet, in typical RV use while camping you can run them down to 80-90% DoD provided that they are recharged promptly. Yes it will reduce the cycle life but in typical RV use that isn't why batteries die. Your Airstream is not a forklift or a floor machine and the batteries are not discharged and recharged 365 times a year.
I run mine down to 80% DoD when I need to which ends up being maybe 3 or 4 times a year at the most. Flooded group 27s. Still going strong after five years.
It is the situation where the batteries discharge in storage and then remain in a discharged state for a long period of time or in freezing conditions that leads to damage.
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Battery Advice? tbro Batteries, Univolts, Converters & Inverters 2 08-06-2009 12:51 PM
battery advice roguebrun Batteries, Univolts, Converters & Inverters 3 03-16-2009 07:09 PM
need Battery and Converter advice for 66' Safari AudioMike Batteries, Univolts, Converters & Inverters 1 07-20-2008 11:14 AM
Battery advice. Mike Leary Batteries, Univolts, Converters & Inverters 7 04-17-2007 08:58 PM
