Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-03-2002, 10:15 PM   #1
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Battery Level Display
My battery level display never gets much above the middle section, even with a fully charged battery at 13.6V
I replaced the battery terminals, cleaned the wiring to the Univolt, redid the ground connections, all with no noticable improvements. I pulled the entire control panel down, but couldnot find any loose wires etc.
This is a 1971 Tradewind 25 trailer.
The system seems to work fine, and the battery holds on for a long time, the Univolt charges very well, but the darn meter is obviously off.
Does anyone have the same scenario?
Uwe
Old 07-04-2002, 10:19 AM   #2
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Red face Battery level display
Got the same problem!! The meter doesn't have an adjustment, either. I have a 71' INt. The ampmeter doesn't work either! I found two wires laying near the univolt , both with right angle connectors. Suspect they belong to the ampmeter?? I think we will have to live with it !!
niftypkg is offline   Reply With Quote
Old 07-04-2002, 10:40 AM   #3
uwe
418
uwe's Avatar
Images: 40
Hey Nifty,
I got no extra wires anywhere, and my ampmeter does do the expected song and dance whe I turnon the waterpump or the ceiling fan etc.
Just these other gauges seem sort of useless.
I might install a different monitoring system inthere one of these days, after I figure out the essentials of the Airstream a little better.
Happy 4th!!
Uwe
Old 07-04-2002, 12:49 PM   #4
Commercial Vendor
Profile:  Corona , California
A voltmeter was used in the older models. It is not a true battery condition indicator in that it does not place a load on the battery. It does however, in a relative manner, tell you that
the battery is sort of up, or sort of down.
The ammeter does have a variable shunt that is built into the univolt. If your univolt has a small copper plate in it with a wire connected to a screw, that screw can be moved, which will change the readings of the ammeter.
But again, the purpose of the ammeter, is relative. It does not need to accurately tell you how many amps you are drawing. It's basic purpose is to tell you that you are charging, of sorts, or not.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 07-04-2002, 07:31 PM   #5
uwe
418
uwe's Avatar
Images: 40
Thanks, Andy
Thanks for the info, Andy.
I can live with this, sort of.
So long that we know if it's doing it's thing, sort of, and that voltage is sort of happening.
Once the lights go dim, we know what's up anyways, no? It's for fun and vacation anyways - I got to keep reminding myself.
Uwe
Pingbacks are On
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Mystifying Battery Problem... heyskipper Electrical - Systems, Generators, Batteries & Solar 19 05-03-2003 10:46 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
SEO by vBSEO 3.1.0
