Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Prev Previous Post   Next Post Next
Old 05-05-2003, 06:24 PM   #1
Profile:
Battery Exploded
I used to take my battery out and put it in the garage in the Winter because I read that one should do that. I put the battery on a Schumacher 2 amp automatic charger that was not supposed to overcharge but I would usually disconnect the charger after about 24 hours. I had to make an emergency trip away from home one time and left the charger on the battery for about a week. While I was gone the battery exploded. Small pieces were scattered all over my garage and battery acid damaged some of the things I had in the garage. This past Winter I just left the battery in the a/s. I have a few questions and would appreciate anyone's suggestions:
Can anyone recommend a charger that I can connect to my battery that will keep the battery charged but will not cause it to explode?
Is it important to remove a battery during the winter and keep it in a warm place? (I haven't had one to freeze in NC yet.)
I have read in some threads where "battery minder" is mentioned. Is a battery minder a special charger that is used to keep a battery charged when not in use?
Thanks for your help.
Wayne
wayner1239 is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 08:44 PM
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 01:50 PM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 06:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
