Old 08-27-2012, 05:25 PM   #1
2007 27' Classic FB
Ridgefield , Washington
Battery Disconnect won't come on
Went to turn on power in the trailer. Pushed "Use" on battery disconnect panel. Light comes on but as soon as I release the button it goes out. 12.5 volts on each battery. We were going out tomorrow to a place with full hookups. Can I still hookup to the 30 amp service without hurting anything?
John & Lisa
Woosch is online now   Reply With Quote
Old 08-27-2012, 05:53 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like a bad relay.
As far as using the trailer, try plugging it in to 120 v, and see if the 12v stuff comes on.
Old 08-27-2012, 06:02 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You should be fine when plugged into shore power. The converter should deliver 120v and 12v power to the rig.
Like Terry said, plug your shore power cord into a regular 120v outlet (you'll need an adapter)...everything should work, including the 12v DC systems and the 120v AC systems...but not the air conditioner and possibly not a microwave (if you have one).
TB & Greg and Abbey Schnauzer
#3954
Old 08-27-2012, 06:55 PM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I sounds to me like the switch is mechanically faulty. Is there any way you can tape it or otherwise force it to stay in the pushed in position?
Keep in mind that I've never seen one of these switches.
Ken
Old 08-27-2012, 07:02 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
John,
Locate the battery solenoid first. They are usually up front near all of your DC wiring busses, close to the batteries, in the same area where your trailer umbilical connects to the trailer wiring. See if the solenoid has any fuses on it (some do) and check them. You may have a bad fuse that is not allowing the solenoid to 'latch' or engage when the switch is in the 'use' position. Airstream uses latching solenoids for the battery disconnects. This is why your momentary battery position switch either opens the solenoid (store) or closes it (use). The light should be on whenever you are in the 'use' position OR whenever you are connected to shore power.
Also, if you DO have a bad solenoid, you will not get any charging to your batteries, even when plugged in to shore power. All of your DC circuits will be energized by your converter, but no charging amperage will flow thru a solenoid that is open.
There is a simple work-around for this if you find the problem. PM me for more detailed trouble-shooting information.
Old 08-28-2012, 08:50 AM   #6
2007 27' Classic FB
Thanks for all the advice. I really need to hunker down and get a better handle on how the electrical system works/ I will let you all know how it turns out.
John & Lisa
Old 08-28-2012, 09:36 AM   #7
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Our trailer did same. Next campground we plugged into, it "Worked". Has been fine since.
knunut is offline   Reply With Quote
Old 08-29-2012, 09:21 PM   #8
2007 27' Classic FB
knunut- Everything seemed fine last night but back to square one after coming off shore power. Checking for fuses on solenoid per Lewsters recommendation. Frustrating. Thanks.
John & Lisa
Old 09-05-2012, 10:38 AM   #9
2007 27' Classic FB
It was a bad switch after all. Kind of suspected it because it was having a harder and harder time catching over the last six months. Thanks.
John & Lisa
Old 01-01-2013, 10:34 PM   #10
Lexington , Kentucky
Battery Disconnect Switch Light
I have a question about the battery disconnect switch? I want to be able to place the switch in the "store" position when plugged-into shore power for long periods of time to keep my new AGM batteries from being overcharged. But if I remember correctly, the red light on the disconnect switch stays on while connected to shore power even if I toggle the switch to the "store" position. Am I correct that the red light stays on (even in the "store" position) when plugged into shore power, and if so, how do I know for sure that the batteries are really disconnected and will not overcharge?
wlanford is online now   Reply With Quote
