Old 12-09-2017, 10:22 AM   #1
Annapolis , Maryland
Battery Disconnect Switch Location
I see a lot of comments about adding battery disconnect switches. Where are folks mounting the switches? Ours is a 27ft FB Twin Flying Cloud.
rhpeahl is offline   Reply With Quote
Old 12-09-2017, 10:37 AM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
These threads cover a lot of the issues. Inside coach, inside box, outside box .... good bad ugly ..... figure it out and do it. Pat
http://www.airforums.com/forums/f542...l<br /> <br />http://www.airforums.com/forums/f37/...-175156-8.html
Old 12-09-2017, 10:47 AM   #3
Wconley's Avatar
2018 28' International
Renton , Washington
Keeping it simple, I installed a switch similar to this to the battery negative terminal. https://www.walmart.com/ip/Everstart...&wl13=&veh=sem
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 12-09-2017, 07:09 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Mount it inside the battery box at the source. That is both easiest and most convenient.
Blue Sea marine grade switch all the way. Gold standard. $30 bucks.
wulfraat is offline   Reply With Quote
Old 12-09-2017, 07:18 PM   #5
2017 27' Flying Cloud
Fort Worth , Texas
Another owner (Mollysdad) and I have been working together to come up with a way to mount the switch external to the battery box in a plastic connection box mounted to the battery box. The advantage of this method is that it does not take up any room in the battery box enabling you to fill that box with the biggest batteries you can fit in there. It also makes it easier to maintain flooded cells with water. The switches are for marine use, so they are waterproof. I agree that Blue Sea is the gold standard. I'm using the 6007 model which is small and provides for being able to disconnect both the airstream and inverter separately.
billrector is offline   Reply With Quote
Old 12-10-2017, 07:38 AM   #6
wulfraat's Avatar
I’ve done it both ways. Inside and exterior mount. I kinda prefer inside if you have the space.
When I mounted to the exterior I simply fastened to the battery box using 2 long bolts that run through the blue sea switch housing.
I also prefer a 4 position switch for flexibility and control over the inverter power.
ID:	300689   Click image for larger version
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
