Old 09-19-2017, 09:02 PM   #1
pt.reyesfan's Avatar
2016 30' Classic
Naperville , Illinois
Battery disconnect switch light
On my Intellitec Battery Disconnect panel the red light is on all the time when I am connected to 110 house power, both when I am in STORE or USE mode. Is that right?
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
pt.reyesfan is offline   Reply With Quote
Old 09-19-2017, 10:18 PM   #2
4riveteers's Avatar
2016 27' Flying Cloud
SF Greater Bay Area , California
Yes, that's correct. You can't turn it off when you're on shore power.
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 09-20-2017, 05:33 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
A caveat - if you put your Use/Store switch in Store Mode and have a power failure your refrigerator won't switch and run on propane (if on automatic setting) as it needs 12v power.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 01-23-2018, 11:36 AM   #4
2015 30' Flying Cloud
Travelers Rest , South Carolina
SO the fact that it is always on when on shore power ... what is impact on batteries?
GallivanGM is offline   Reply With Quote
Old 01-23-2018, 11:41 AM   #5
4riveteers's Avatar
We installed an upgraded smart 4 stage charger. If you done have a smart charger you will over charge the batteries and smoke them! Bad seen and they will smell like rotten eggs.
Old 01-23-2018, 12:11 PM   #6
2007 22' International CCD
Perfectly normal.
The stupid light DOES NOT tell you the state of the battery switch.
It's wired to simply tell you that you have 12 volt power available for your 12 volt appliances. It has NO idea if your batteries or convertor are providing the power.
After a lot of analysis and research, I found out that there is no other way to make it work, because the relay that the use/store switch actually controls is a mechanically latching relay that provides NO indication of its position. You have to hit the switch to the appropriate selection and listen for the 'clunk' noise to verify something happened....
I'm replacing that POS with a real Blue Sea latching battery contactor and associated switch/indicator that tells me if it is activated or not...
Old 01-23-2018, 01:24 PM   #7
Mollysdad's Avatar
As I understand it, the light lights when shore power is detected.
It doesn't matter if it's in "use" or "store".
Old 01-23-2018, 02:00 PM   #8
Just 12 volt power present...doesn't care if its battery or convertor supplying it.
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 32 08-26-2019 01:23 PM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Electric perplexity: Opinions solicited, pump,disconnect switch, fluor light sympto hshovic Batteries, Univolts, Converters & Inverters 2 11-19-2008 08:25 AM
