Old 06-03-2015, 04:23 AM   #1
2004 19' Bambi
Tyngsboro , Massachusetts
Battery disconnect switch
Hi new owner of a 2004 19' Bambi and i'm noticing the battery disconnect switch's red light is always red, so I can't really tell if it's connected or not. Is this a normal condition.
Thank you
Ernie
ErnieRoy is offline   Reply With Quote
Old 06-03-2015, 04:38 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Unfortunately that switch is poorly designed and it will always glow red. The only way to determine whether or not it is "on" is to toggle it and see what happens. If the 12 volt lights don't come on, then you've got it in "store" position.
Bob Martel
WBCCI# 5766
Old 06-03-2015, 05:25 AM   #3
bwpaint's Avatar
2015 25' FB International
my , house
Mine remains lighted if plugged into shore power. Goes out if switched to store position when unplugged.
bwpaint is offline   Reply With Quote
Old 06-03-2015, 06:17 AM   #4
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Batt disconnect switch
It's an odd switch not logical. If It's off there will be no light on (store) if you plug the power cord in it should light up even without moving the switch. You can use everything in the camper at this point. Now if you want to send power to the battery for charging you will need to push the button to use you will hear a sound as you push button now the converter/charger is sending power to the battery. You can check this with a voltmeter at the battery posts. Before and after pushing the use button. If you are not plugged in and want to use the 12 volt systems You will need to push the button to use the light will come on. The converter/charger that comes standard in AS's is poor in that it only sends a single voltage to battery and takes a long time to charge and can over charge if left on too long. I changed mine to a progressive dynamics PD4655 a three stage charger an easy up grade and works well. Good camping Rand
grizbear is offline   Reply With Quote
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
