Old 04-24-2019, 08:59 AM   #1
2014 25' FB Flying Cloud
Vancouver , British Columbia
Battery Disconnect Removal
I have a master battery switch in my TT that turns off everything including parasitic loads. Do I still need the OEM Battery Disconnect or can I remove it?
RubyDog is offline   Reply With Quote
Old 04-25-2019, 10:03 AM   #2
2015 30' Classic
Pleasanton , California
Are you referring to the Use/Store switch and associated relay?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-25-2019, 11:42 AM   #3
Mollysdad's Avatar
I kept mine. It just gives you more options.
Old 04-25-2019, 12:47 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
With our Classic you can have the U/S in the store mode and still have 120v in the trailer and charge the batts.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-25-2019, 07:58 PM   #5
Yes. All it does is disconnect the DC panel which is why you still have parasitic loads. It just seems redundant to me.
Old 04-27-2019, 12:16 AM   #6
2015 30' Classic
Like Bob says, you can disconnect your battery even when you're connected to shore power. This might be useful if you intend to be connected to shore power for an extended period and perhaps you don't want to risk overcharging your battery from your single-stage converter.
Al, K6IV
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
Car Battery Low Disconnect in '68 crair Batteries, Univolts, Converters & Inverters 3 06-13-2006 05:29 PM
Battery Disconnect Light FiveGreers Electrical - Systems, Generators, Batteries & Solar 2 04-03-2006 08:01 AM
