Old 01-18-2015, 04:08 PM   #1
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Battery discharge question
Gang,
We have a 2014 27ft fb International with a 100w solar panel that will bring up two newly replaced group 24s to 12.5v according to the See-Level monitor by the end of a sunny day. However by the next morning the monitor normally reads in the mid to high 11s, e.g. 11.5-11.9.
When the batteries were replaced under warranty the dealer allegedly checked for shorts that would draw down the batteries and found none, and attributed the dead batteries to simply being bad, old or??? We have the normal power-suckers, CO2 monitor, fridge, in addition to a power awning with a "brain" that is drawing power whenever the rig is in the "use" mode. We are very conservative and do not run the furnace at night, turn off the water pump, sound system's main power, and burn no lights.
Given we have read that one should not allow the batteries to discharge more than 50% for fear of ruining the batteries (some say 40%), and considering the conversion table that has been posted to the forums says a battery reading 11.75 is at 30% state of charge, do we have a problem, or may I be reading the table incorrectly?
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 01-18-2015, 05:52 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Actually, full batteries are NOT 12.5VDC, but more like 12.8VDC and 50% depth of discharge is 12.2VDC (some folks list 12.7VDC as 100% and 12.1VDC as 50% for liquid lead acid batteries). Your batteries are never reaching full charge of the only get to 12.5VDC, and may not be retaining sufficient charge if the regularly discharge to 11.5-11.9VDC on a daily basis.
You should have your batteries checked for charge retention once they have been properly charged to FULL, not to 12.5 VDC. You also might benefit from a total trailer disconnect switch that will remove the battery power completely from the trailer's electrical system.
TV battery discharge while plugged in? Peanut Electrical - Systems, Generators, Batteries & Solar 12 01-09-2015 06:34 AM
Battery Discharge bertheep Batteries, Univolts, Converters & Inverters 10 08-28-2011 10:07 AM
battery discharge wolf146 Batteries, Univolts, Converters & Inverters 11 04-24-2010 07:56 AM
battery: phantom load, or normal discharge? Chuck Batteries, Univolts, Converters & Inverters 12 08-25-2004 01:13 AM
leaky gaskets in waste discharge jaiman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-01-2003 05:11 PM
