Old 01-17-2018, 08:14 AM   #1
2017 25' Flying Cloud
Raleigh , NC
Battery Cutoff Switch Install for 6v Batteries
We have a 25' 2017 Flying Cloud. I have purchased a pair of Trojan 6 volt AGMs. As part of the install, I would like to add a three way battery cutoff switch (Off, On Power & Inverter, On Power, Inverter off). I have been looking at different ways to fit a Blue Sea switch the box along with the batteries.
Can anyone that has accomplished adding a cutoff switch in or near the battery box offer an where/how to do it given the space limitation?
Thanks!
JoeHTP is offline   Reply With Quote
Old 01-17-2018, 08:44 AM   #2
2007 22' International CCD
IIRC, the Blue Sea switches are waterproof. I'm mounting mine on the outside of the battery box, surface mounted with 4 pan head stainless steel screws from the inside of the battery box into Nylock nuts that fit into the recesses in the front of the switch.
Yeah, it could be tampered with...if that's an issue, I think they make ones that lock with a key.
Be sure to size the short battery lead from battery positive post to the switch more than beefy enough to take the inverter as well as the usual house loads. I don't know where you might mount the inverter and house main fuses--perhaps a rather big one right at the battery terminal to protect all the wiring and the switch from excessive current
Be very sure to protect all the exposed cables from chafing, sunlight, and mechanical damage--you're talking a LOT of energy potentially flowing in those cables...
Lewster, chime in?
Old 01-18-2018, 07:34 AM   #3
Raleigh , NC
Thanks for the advice. Follow up question - if you mount on the outside of the battery box (which I think is a good approach), I assume you have to drill holes in the battery box to pass the cables through? In that case, it would seem like you would need 90 degree lugs to connect, since the big cables do not flex?
Joe
Lewster, chime in?
Old 01-18-2018, 07:43 AM   #4
FishByFly's Avatar
Oak Park , Illinois
This is my setup. You can see the Blue Sea switch outside the battery box in the lower left of the pic. I chose the switch in Black to conceal it a bit. Click image for larger version
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 01-18-2018, 09:24 AM   #5
Raleigh , NC
Thanks for the photo. From what I can tell your cables run in and out of the existing hole in the battery box and into the switch. Do you need to waterproof the entry into the switch, and is some kind of drain hole needed in case water gets in?
Good call on the black box, it blends right in!
Joe
Originally Posted by FishByFly View Post
This is my setup. You can see the Blue Sea switch outside the battery box in the lower left of the pic. I chose the switch in Black to conceal it a bit. Attachment 302609
Old 01-18-2018, 01:26 PM   #6
FishByFly's Avatar
Oak Park , Illinois
I just wired the switch as it came. I mounted it similarly as rmkrum described with pan head screws and concealed nuts. Nothing special on making it “more” watertight as I am not expecting it to get submerged. Moisture that gets in can drain out the bottom or evaporate.
I did increase the gauge of all wires from here into the batter box and within the box itself. Used all the existing routing. Used lug connections for everything at the battery.
This was the first season that I only have to open the battery box to check the water in the batteries.
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Cutoff switch xrvr Batteries, Univolts, Converters & Inverters 0 12-12-2015 05:31 AM
Protecting the master cutoff switch Bikerbill Sprinter and B-van Forum 11 02-13-2014 01:34 PM
Battery cutoff switch contradiction - 2007 Classic dznf0g 2006 - 2010 Classic (all lengths) 0 09-29-2010 08:10 PM
Battery Cutoff Switch Silverbee Electrical - Systems, Generators, Batteries & Solar 16 09-13-2010 06:00 PM
