Old 09-12-2010, 07:03 AM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Battery Cutoff Switch
Have a 2007 Safari SE-20ft. Need some help understanding just how the battery cutoff switch works and just what it does.
Silverbee is offline   Reply With Quote
Old 09-12-2010, 07:28 AM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Battery Disconnect Switch
Tom,
Personally, we use the on position whenever we are using the Airstream whether 110v is available or not.
We use the store position when the Airstream is not in use and not plugged into shore power to keep phantom electrical drain from things like the LP detector, radio, etc.
This is directly out of the Owner's Manual:
BATTERY DISCONNECT SWITCH
The disconnect switch is used to separate the batteries from the 12-volt distribution panel and converter charging system.
When the switch is turned “use” (on) and the trailer is plugged into a 110-volt shoreline, the 12-volt distribution panel will receive power from the converter and the batteries will be charged through the converter charging system.
When the switch is turned to “store” (off) and the trailer is plugged into a 110-volt shoreline, the 12-volt distribution panel will still receive power from the converter, but the batteries are disconnected from the system. The batteries will not be drained with the switch in the store position. The converter will not charge the batteries with the switch in this position.
The charge in the 12-volt batteries is replenished when towing from the tow vehicle alternator through the 7-way cord. This charge will go to the batteries no matter which G position the Battery Disconnect Switch is in.
fltlevel510 is offline   Reply With Quote
Old 09-12-2010, 09:03 AM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by fltlevel510 View Post
Tom,
I discovered by accident that even when the switch is turned to store there is still some parasitic drain on my batteries. (2005 Classic 30)
I found this out because I was connecting the batteries one day with the switch in "store" position and noted a spark when I hooked up teh battery terminals. That indicates current flow. I didn't attempt to measure the current & have no idea what was being fed.
I could be mistaken, but I seem to recall someone on this forum saying that not everything is disconnected when in the store position - although I don't see the logic to that.
Maybe my store switch is defective?
In any event what I did to easily be sure that the batteries were truly disconnected when I wanted them to be was to install quick disconnects onto each battery that just require a quick turn of a knob on the terminal clamp to disconnect or reconnect the battery.
Two such quick disconnects needed, they cost me $5 each as I recall from Harbor Freight and work fine.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-12-2010, 09:11 AM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
The wire for the propane detector bypasses the kill switch. This is because, once powered up, the propane detector deteriorates if it is not powered constantly.
If you download a manual from Airstream.com and look at the wiring diagram, you will find the bypass wire shown.
Later manuals do not have the wiring diagrams. You have to go back to about 2005 to find the diagram. You can extrapolate from one model to another since they are all pretty much the same.
John W. Irwin
WBCCI #9632
Old 09-12-2010, 09:17 AM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The propane detector and the break-a-way switch and the Electro-hydraulic brake actuator (if you have one) are all hot all the time. My tongue jack was hot as well.
Michelle TAC MT-0
Sarah, Snowball
Old 09-12-2010, 09:22 AM   #6
Wingeezer's Avatar
2005 30' Classic
Hmm, that's interesting - I should read the blurb that came with my propane detector to see if it gives any warning of that.
Doesn't seem good as I expect many people who cannot store their trailers at home, me included, remove batteries from their trailers when stored for a while and take them home to put them on charge.
Wonder how much it affects the life of the propane detector? I guess smoke detectors, CO detectors, and propane detectors should probably be changed any way every 5-10 years or so in any event as a precaution.
Brian.
2005 Classic 30'
Old 09-12-2010, 09:29 AM   #7
Wingeezer's Avatar
2005 30' Classic
Seems a lot of our trailers may be wired a bit differently with respect to that isolation switch.
I suspect my propane detector is still connected, as something is certainly drawing current in teh store position.
I wouldn't be surprised if the brake emergency switch is still connected too, that would make sense, although of course it would not normally draw current unless tripped, in which case you;d lose your batteries in short order - and maybe your brake magnets!
I do know for a fact however that in my case, the tongue jack on our trailer won't work if the isolation switch is in store position. At first I thought my tongue jack had become defective until I learned that! Maybe the PO has altered the wiring for some reason.
Brian.
2005 Classic 30'
Old 09-12-2010, 06:53 PM   #8
dznf0g's Avatar
Oswego , Illinois
I think that only the propane detector draws current in the store position. (at least according to my manual) It makes sense that the breakaway switch would have power, but no draw unless polled out. Of course this would mean that the actuator would have available power....but does it have any parisitic "keep alive" circuits, or is it "dead" unless the breakaway switch is pulled?
Old 09-12-2010, 07:15 PM   #9
Keymar , Maryland
The computer in the Actuator is always on. Slight draw.
Michelle TAC MT-0
Sarah, Snowball
Old 09-12-2010, 07:35 PM   #10
dznf0g's Avatar
Oswego , Illinois
That makes perfect sense. Now for the million dollar question. Has anybody tested the total parisitic draw when the switch is off? If I'm only going to store it for 2 weeks at the lot (no shore power available) do I need to disconnect the batteries? 3 weeks? a month? (I doubt it). Assuming 2 healthy deep cycle batteries. I have them disconnected now for a 2 week lonely absence.
Old 09-12-2010, 07:46 PM   #11
richinny's Avatar
2011 34' Classic
similar question:
http://www.airforums.com/forums/f449...why-67735.html
Ricky
Old 09-12-2010, 07:58 PM   #12
dznf0g's Avatar
Oswego , Illinois
I think I'll just install the quick disconnects at the posts and stop "anal"izing it!
Old 09-12-2010, 08:57 PM   #13
2003 22' International
Waverly , Pennsylvania
I have a strange situation when using my battery cut-off switch. If I turn the switch off it cuts off any 12 volt functions, then if I turn the switch back on all 12 volt functions are still non-functioning. The only way to restore the 12 volt functions is to plug into an external electric source. The battery can have a full charge when this occurs.
Also, my battery does not charge while the tow vehicle is running. I changed the fuse in the tow vehicle battery line thinking this was the problem. If the battery runs down while dry camping we are out of luck until we plug into electric.
Any ideas?
nayl is offline   Reply With Quote
Old 09-13-2010, 02:24 PM   #14
Keymar , Maryland
If you disconnect the batteries and have an actibrake or simular you need to re-sync with the brake controller when you hook the TV back up to the trailer.
Michelle TAC MT-0
Sarah, Snowball
Battery switch? roblo101 Batteries, Univolts, Converters & Inverters 8 11-10-2009 12:18 AM
Battery Isolation Switch Use? Wingeezer Batteries, Univolts, Converters & Inverters 14 08-28-2009 10:28 AM
Battery switch HELP? Archersfin Batteries, Univolts, Converters & Inverters 5 07-14-2009 08:35 PM
Battery Cutoff Swithes noiva Mechanics Corner - Engines, Transmission & More... 16 09-21-2006 02:03 PM
New battery switch - 2003 Classic Pahaska 2001 - 2005 Classic 15 05-29-2005 08:28 PM
