09-24-2014, 05:24 AM
2010 20' Flying Cloud
Christchurch
, Canterbury
Battery converter not charging battery
Hi, I am connected to shore power, but the battery converter doesn't seem to be charging the battery, what could have gone wrong? Normally when I connect shore power, the battery converter would send 13v to the battery to charge it. I unplugged shore power today, thinking the battery is charged up ready to go, but nop it's flat with just 6v, no lights
I can't imagine this to be a major issue, must be something that is loose or some fuse blown? Please help me trouble shoot, much appreciated! keen to go camping now it's spring time in New Zealand
09-24-2014, 10:25 AM
2006 23' Safari SE
I'm In
, Kentucky
The Use/Store switch needs to be in Use. Where is your switch set?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Princeton
, New Jersey
Did you have lights while the shore power was connected? If so you have a shorted battery.
2004 Excursion 4x4
09-24-2014, 10:58 AM
2008 25' Classic
Full Time
I had this happen on my preowned 2008 Classic 25fb. The Parallax converter was not outputting at the battery connections. I used a multimeter to check. I'm surprised the dealer I purchased it from couldn't figure it out. I went camping after the "repair" and the batteries still discharged when plugged in to shore power. I had to buy a battery charger in a nearby town to save the trip. I ended up buying a Progressive 4655 from Bestconverter and installed it myself. Now I have a 3 stage converter which is a good upgrade.
Kelvin
09-24-2014, 03:47 PM
Christchurch
, Canterbury
Probelm solved. It was just a simple battery cut off switch, was on store and should have been set to use. Kind of a silly bug easy to miss and can drain batter juice while camping. Airstream can perhaps solve this by dummies proof it to make it charge the battery regardless of the cut-off switch. Thanks all for your feedback!!
09-24-2014, 03:55 PM
2014 25' FB International
Little Rock
, Arkansas
That switch caused me to ruin two sets of batteries in our last AS. When we picked up our 2014 this spring I replaced the converter the next week. Now I leave the batteries charging all the time and I don't have to worry about the batteries getting cooked.
10-21-2023, 12:01 PM
2018 28' International
Dover Plains
, New York
I have a 2018 28' International that's awesome when all works. Today, when I turn my furnace on with my Dometic thermostat, I no longer have a sand clock icon in the screen, nor do I hear the blower motor click on. Fan is on auto, heat is set to 74 degrees, camper interior temp is at 55 degrees, no furnace. Any thoughts
10-21-2023, 03:10 PM
1988 32' Excella
Robbinsville
, New Jersey
Sometimes the thermostat needs to be reset.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Help! Battery not charging, outlets not working when plugged in
AirGal04 |
9 |
06-06-2014 09:15 PM |
steven2themax |
6 |
11-05-2010 12:52 AM |
Tow vehicle not charging battery
ESCAPE POD |
6 |
07-11-2010 10:57 PM |
Intel not charging battery
Lothlorian |
10 |
11-22-2008 02:48 PM |
OOPS! battery not charging,water hook up spilling into reserve tank?
outerbanksdeb |
2 |
08-02-2004 12:40 PM |
