Old 09-24-2014, 05:24 AM   #1
airstreamz's Avatar
2010 20' Flying Cloud
Christchurch , Canterbury
Battery converter not charging battery
Hi, I am connected to shore power, but the battery converter doesn't seem to be charging the battery, what could have gone wrong? Normally when I connect shore power, the battery converter would send 13v to the battery to charge it. I unplugged shore power today, thinking the battery is charged up ready to go, but nop it's flat with just 6v, no lights
I can't imagine this to be a major issue, must be something that is loose or some fuse blown? Please help me trouble shoot, much appreciated! keen to go camping now it's spring time in New Zealand
airstreamz is offline   Reply With Quote
Old 09-24-2014, 10:25 AM   #2
richw46's Avatar
Lexington , Kentucky
The Use/Store switch needs to be in Use. Where is your switch set?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-24-2014, 10:25 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Did you have lights while the shore power was connected? If so you have a shorted battery.
2004 Excursion 4x4
Old 09-24-2014, 10:58 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I had this happen on my preowned 2008 Classic 25fb. The Parallax converter was not outputting at the battery connections. I used a multimeter to check. I'm surprised the dealer I purchased it from couldn't figure it out. I went camping after the "repair" and the batteries still discharged when plugged in to shore power. I had to buy a battery charger in a nearby town to save the trip. I ended up buying a Progressive 4655 from Bestconverter and installed it myself. Now I have a 3 stage converter which is a good upgrade.
Kelvin
Old 09-24-2014, 03:47 PM   #5
airstreamz's Avatar
Probelm solved. It was just a simple battery cut off switch, was on store and should have been set to use. Kind of a silly bug easy to miss and can drain batter juice while camping. Airstream can perhaps solve this by dummies proof it to make it charge the battery regardless of the cut-off switch. Thanks all for your feedback!!
Old 09-24-2014, 03:55 PM   #6
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
That switch caused me to ruin two sets of batteries in our last AS. When we picked up our 2014 this spring I replaced the converter the next week. Now I leave the batteries charging all the time and I don't have to worry about the batteries getting cooked.
Landrum is offline   Reply With Quote
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
Battery not charging steven2themax Batteries, Univolts, Converters & Inverters 6 11-05-2010 12:52 AM
Tow vehicle not charging battery ESCAPE POD Batteries, Univolts, Converters & Inverters 6 07-11-2010 10:57 PM
Intel not charging battery Lothlorian Batteries, Univolts, Converters & Inverters 10 11-22-2008 02:48 PM
OOPS! battery not charging,water hook up spilling into reserve tank? outerbanksdeb Batteries, Univolts, Converters & Inverters 2 08-02-2004 12:40 PM
