Old 05-16-2003, 06:27 PM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Question Battery compartment...How to?
The black vinyl battery holder, I'll call it a nest, in my newly acquired '73 Tradewind is attached to the
compartment door. The lip of the nest is snuggled under flanges A and B (see pic) and also held in place by the 2 nuts on the handle screws. Flange A is a moulded part of the door. Flange B is a seperate strip which appears to be held in place by the same 11 rivets that attach the piano hinge.
I need to detach the nest it but I am stumped. The door won't close if the battery just sits loose in the compartment. There must have been a rhyme or reason for this configuration but I'm getting a bald spot from scratching my head. Has anyone encountered this? Help, please?
Rog
Rog0525 is offline   Reply With Quote
Old 06-15-2003, 10:22 PM   #2
batteryspace
Possibly my non-educated guess would just be to accomadate slightly batetteries if need be
Phaedrus is offline   Reply With Quote
Old 06-15-2003, 11:29 PM   #3
Rog0525's Avatar
Images: 11
Problem solved
Thanks, resolved the problem before the forum crash thanks to input. Battery was too big, bought a smaller one. Duh.
Rog
Old 06-16-2003, 08:37 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I just bought a Trojan 30XHS, (130 AH) and it fits in there fine. I suppose you could set an additional battery on the door nest and wire them in parallel while stationary. Sometimes the cables bunch up in front of the battery and that prevents the door from closing properly.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-17-2003, 10:58 PM   #5
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I'll Second what Pick mentions about the "battery cables bunching up in front of the door"--this is something to watch out for. It's happened to me numerous times and causes the door to pop open unexpectedly.
At one time I measured and was fairly sure that two Optima Blue Tops would fit perpendicular to the intended battery orientation if the platform was removed from the door and a proper method of securing them was fashioned so they didn't fall out when the door was opened.
(I did not do this because of concern over extra weight on the outrigger and it's location behind the axles.)
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Battery Box Compartment AccessMaster Airstream Motorhome Forums 11 05-03-2003 09:00 PM
Doors for Battery and Stowage Compartment Joe Davis Exterior Storage Compartments & Access Doors 4 03-07-2003 06:27 AM
battery compartment mods nwclassic Our Community 13 02-18-2003 06:46 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
