Old 05-31-2015, 03:24 PM   #15
2014 23' Flying Cloud
Rhinebeck , New York
Talking Batteries in "storage"
Originally Posted by larryglarson View Post
I have left mine plugged in for 5 years, no problem. I do not experience much electrical usage.
Same for us. Although for just one winter so far!!
Adam Geuss is offline   Reply With Quote
Old 05-31-2015, 05:40 PM   #16
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
Our AS has a battery cutoff switch inside a front interior compartment. I turn it off when storing and wire a battery maintainer to the battery which I plug into a timer that comes on for thirty minutes a day. The stock system is supposed to not over charge but I lost three batteries in about five years.
dalemonroe is offline   Reply With Quote
Old 05-31-2015, 08:34 PM   #17
2013 16' Sport
Boulder , Colorado
Good idea to unhook the batteries and take them inside in the winter if you live in a cold climate -- and hook them up to a battery tender as others have suggested.
Seecue is offline   Reply With Quote
Old 05-31-2015, 09:25 PM   #18
1974 Argosy 20
Kooskia , Idaho
Totally unnecessary to do anything but to charge them up then unhook them. See my post and test on 5 months of battery storage at 0 to 5 degrees F.
http://www.airforums.com/forums/f449...ml#post1602338
Old 06-01-2015, 04:06 AM   #19
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
People in Alaska, northern Canada, North Dakota leave tractors and trucks sitting all winter long in sub zero weather without doing much other than as Idroba says. The liquid in a charged battery is not the same thing as water.
Batteries self-discharge without anything hooked up to them, but if they have not been repeatedly discharged below a level of charge ( which varies with battery type) they should charge back up again without any problems.
If using a trickle charger, the best ones are like the MPPTs we use on boats. They allow you to adjust the float rate. A float rate of 13.8 volts I think, for lead acid batteries, will vaporize some electrolyte after a while. This means that the acid level in the batteries will drop down toward the plates if you don't top them up.
If you can adjust the float of your charger to 13.2 volts for the winter, the batteries don't gas during charging.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 06-01-2015, 10:39 AM   #20
2013 16' Sport
Boulder , Colorado
Great info! I was mis-informed about the effects of cold temps on the battery -- thanks for the real-world testing. I'm delighted that we can now forgo the annual ritual of dragging the batteries inside!
Old 06-01-2015, 11:18 AM   #21
Wise Elder
Jammer's Avatar
2010 30' Classic
I have the stock converter and original batteries in my 2010. I leave it plugged in when parked, although care is required to be sure the water heater and electric heat are off.
The stock converter is not temperature compensated and will tend to overcharge batteries in hot weather. I check them every few weeks and add distilled water if needed, usually just once a year.
In cold weather, the stock converter won't fully charge the batteries, but it will keep them charged enough that they won't freeze.
Old 06-01-2015, 12:30 PM   #22
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
How is leaving the AS plugged in for storage any different than leaving plugged in for 3 months when are living in it in Florida?
Gary
Castaway is offline   Reply With Quote
Old 06-02-2015, 06:12 AM   #23
1996 25' Excella
Tillsonburg , Ontario
Re freezing of batteries
If your battery is really discharged, then the specific gravity of the battery acid is low enough that it will freeze at somewhere below 0 F. Fully charged battery will withstand -40 easily. So if you live in a really cold winter area you just need to be sure the batteries will hold their charge in storage.
JCW
JCWDCW is offline   Reply With Quote
Old 06-30-2017, 02:04 PM   #24
2017 25' Flying Cloud
Durango , Colorado
Originally Posted by Silver Hawk View Post
When I first got my AS I kept it plugged in (new 3 stage converter) when not being used. It worked fine, but I was amazed with the extra electrical bill cost. I disconected the batteries and put a battery minder on them and the bill was so small I couldn't tell it was on.
Now I have installed a solar that takes care of it at no cost through the converter.
No more unhooking and re-hooking up!
Also when I travel and boondock I don't have to use my generator.
May I ask about your solar installation details, I'd like to do more boon docking but I don't have a generator yet, thanks
Coalman is offline   Reply With Quote
Winter storage battery charging. obsail 2016 - Current International 29 11-30-2016 01:55 PM
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 02:25 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
