Old 03-14-2013, 11:19 AM   #1
Puyallup , Washington
battery charging
Does my truck connector charge the batteries on my airstream 19.
trailer is a stock 2012
srpuywa is offline   Reply With Quote
Old 03-14-2013, 11:22 AM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Yes, look in your manual. Mine states the battery is charged by the TV whether the battery switch is set in store or use position. Read it last night.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-14-2013, 12:10 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Keep in mind that charging from the truck will take many miles to re-charge depleted batteries. Modifications in the wiring can be made that will permit much more efficient charging but with factory truck wiring it will take awhile. I had dead batteries a few years ago and it took several hours of driving before the refrigerator would start cooling and I think that's only about 4 amp usage.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 03-14-2013, 12:51 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Yep, although for some trucks you have to add a fuse or hook up an extra wire or something for it to work.
In practice I find that I get around 10 amps per battery this way, so it takes 10 hours of driving to go from completely dead to fully charged. Still, it makes a difference.
Old 03-14-2013, 01:04 PM   #5
BAB
BAB's Avatar
2015 30' Classic
Greensboro , North Carolina
It does, and as noted, it takes a lot of driving to recharge your trailer batteries. If I boondock and I've driven all day, I still run my Honda 2000 for an hour or so to make sure the batteries are topped off by the end of the day. I don't think I'm a power hog, but the fridge, etc draw the 12V....and I have an inverter so I'm known for watching some TV so I know what's going on in the local world!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-14-2013, 01:30 PM   #6
dznf0g's Avatar
Oswego , Illinois
I've never had an issue with a complete recharge while driving. BUT!!! I run a big fat charge line with a self resetting 30a breaker direct from B+.
-Rich-
