Old 11-28-2008, 07:14 PM   #1
frscott's Avatar
1986 25' Sovereign
Wichita Falls , Texas
Battery Charge
I have had my '85 Sovereign for about 6 months now, and accidentally left the fridge on and killed the two batteries. I was doing some maintenance and had the trailer plugged into the house, and decided to take out the batteries for recharge, only to find that the battery lines were very live! I am not an electrician, so I am wondering if power to the batteries means that they will recharge when the trailer is plugged in? Will the batteries get too charged if I leave the trailer plugged in?
frscott is offline   Reply With Quote
Old 11-28-2008, 08:03 PM   #2
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
When you plug in your trailer to 120 volt out side line they will charge so no removing of battery to charge is needed.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 11-28-2008, 08:57 PM   #3
campman's Avatar
1979 Argosy Minuet 6.0 Metre
JACKSON , Mississippi
Send a message via Skype™ to campman
In six months and no recharge, they probably are totally dead and cannot recharge. Doesn't your unit have a charger and 3 stage inverter hooked up to the batteries? If so, when not in use (and if water level is up and pH is correct..usd a hygrometer), they should keep a charge. I found two sets of info but am not sure of the exact forum or thread...that are just about the best education you could get on batteries and their care. Use the search feature. Here is the title of Part 2 of that information; it may help you find it: It is several pages and illustrations...top notch...
The 12 volt Side of Life Part 2.
Good Luck.
Dan in Mississippi, formerly of Ohio, New Hampshire, Alaska, New York and New Guinea...among others.....
From Paul Theroux: ..the difference between a traveler and a tourist is.."travelers don't know where they're going, and tourists don't know where they've been"
campman is offline   Reply With Quote
Old 11-29-2008, 04:25 AM   #4
1977 31' Sovereign
Images: 33
Here is anothergood question..
Good Luck.
Where do you find a load tester ?
That might be a good investment if not you can bring your battery's to a pep boys or autozone and have them load test it to see if it can still hold a charge.
K/N Cool intake air
Duel power exhaust
Old 11-29-2008, 08:49 AM   #5
frscott's Avatar
1986 25' Sovereign
Thanks to all for the help! I did have to replace one of the batteries, so you wee right about the concern for a dead one. I will do the search for the article mentioned, because I still have no idea where the inverter is-though I know there is one since I get AC inside the unit, but as far as a charger, I have no idea where to look. But at least I know to plug it in while it is parked! Maybe I need a week at Airstream training school??
Old 11-29-2008, 08:57 AM   #6
1975 29' Ambassador
Reno , Nevada
Yes, the battery lines will be live when you have 110v connected. That is the function of the RV converter. It 'automatically' charges the battery whenever you connect the trailer to 120vAC power.
Forget hydrometers and load testers. That is _so_ old tech! Hydrometers require hazmat precautions and have a good likelihood of contaminating your batteries. Load testing is destructive. Modern techniques use voltage and a conductance tester to determine the state of charge and state of health of a battery.
If your batteries were flat dead for any length of time, it is likely that they are damaged and need to be replaced. The easiest way to tell is to see how long they will keep the trailer lights bright (this is a simple load test).
Note that many RV converters will do OK to charge batteries but not so hot when it comes to storage maintenance. Storage requires particular attention to charge topoff and desulfation. The WFCO or PD+CW converts do this. The Battery Minder (tm) is another option.
Old 11-29-2008, 10:54 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
Whoa there...I've been in the Battery Biz for many years, and have seen those 'electronic' testors come and go over the years...but they really can't replace hydrometers and load testors when you're trying to find out what's going on inside your batteries!
All battery Mfg's indeed still use hydrometers AND load testors in their Mfg. process'. We use em' every day in our shop, too! I've never heard of a hydrometer contaminating a battery...???
A hydrometer is the only true way to check the state of charge of you battery...voltage only gives an 'indication' of the charge status, and only after it's been 'rested' for over 24 hours without any charge or discharge.
Load testing of a charged battery will NOT destroy it! Sure one could keep the load on the battery till it discharges completely, but that's not how it's used.
A load testor will indicate cell problems in your battery, IE if plates are shorted, etc, due to breakage or sulfate build up...
Also, it's not wise to replace only one battery in a two battery bank if they are older than two years...the new battery will not perform as well, as the older battery's internal resistance will be different, causing the charging system to shut down sooner and nor allowing the new battery to get fully charged.
Batteries need to be fully charged to give long service life...and they're life will be shortened if you discharge them below 50 per cent all the time, or let them 'sit' in an undercharged condition for any length of time, such as when in storage...the battery in your TV or car lasts for years as the alternator keeps it fully charged all the time...your RV deep cycle batteries are no different in that regard, keep em' charged up for longer life!
Ray & Pat; Morada, CA
Old 11-29-2008, 10:54 AM   #8
campman's Avatar
Leipper...that is hyGrometer, not hydrometer...anyway, your technical advice is difficult for a novice like frscott. FRSCOTT; The converter/charger should be right in the same general space as your batteries (however, the batteries are always set off in specific space for safety). I found the REALLY GREAT BATTERY INFO SITE HERE:
WWW.CCIS.COM/HOME/MNEMETH/12VOLT/12VOLT.HTM
It is all easy to understand and will teach you a lot. I printed the first one off and then put the other one in my favorites for later learning.
Anyway, owning an RV or other unit is part of keeping you young by learning new things. Good Luck
Old 11-29-2008, 11:21 AM   #9
campman's Avatar
Sorry..I was way off base and wrong...it IS hydrometer. An hygrometer measures humidity. Stupid of me.. Anyway, they are cheap and easy to use and in no way could harm a battery. Get one.
Old 11-29-2008, 11:34 AM   #10
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
FWIW -
- "Inverter" is an electrical device that converts direct current (DC) to alternating current (AC). An inverter allows you to use store energy in your batteries to power devices that require 120v electricity (i.e. TV, mobile phone recharger, etc.)
- "Converter" is an electrical device that converts 120v AC to 12v DC. In the RV world, converters generally also include a battery charger. This device supplies a 12v DC power source to everything in your trailer that requires 12v (lights, 'fridge, water pump, etc.) as well as charges your house batteries.
All Airstreams have a converter/charger. Inverter is a paid for upgrade.
ostream is offline   Reply With Quote
Old 11-29-2008, 11:43 AM   #11
1975 29' Ambassador
Reno , Nevada
oh my, I really don't know why I rouse such hostile sentiments. And complaining that "your technical advice is difficult for a novice like frscott " when I didn't get technical is interesting, too. Oh well, for those who can keep an open mind, here are some references to check to find out where I got my wild, wacky, and offensive ideas.
It is indeed easy to get the d's and g's confused, but do check hydrometer vs hygrometer in the dictionary. If you take a look at proper use of hydrometers in batteries, you'll see that they require as many caveats about temperature, battery state, and other factors as does voltage testing. But let's be careful about getting too analytic and letting precision overrun accuracy in our RV battery measuring.
A couple of references on background for measuring state of charge include Battery State of Charge Determination and SmartGauge Electronics - Specific Gravity and State of Charge - these require careful reading to understand how specific gravity and voltage are related. As an example note that smartgauge basis its battery meter on an analysis of voltage. The smartgauge site has a number of very good essays on topics pertinent to RV battery systems.
The fact is that with modern DVM's and a proper measure and its interpretation, voltage can be useful for the typical RVer for determining battery state of charge. Considering the difficulty (or even impossibility in the case of sealed batteries) of getting to the battery cells plus the risks involved in dealing with battery acid, a voltage measure can do well enough.
re "have seen those 'electronic' testors come and go over the years" - nope, not those. I mentioned conductivity testors. They have been around since early 1990's. See Rapid testing of batteries at Battery University.com for a nice rundown on methods. Search 'battery conductance testing' to learn about this.
See Basic battery guidelines for some basic RV oriented guides and a link to all sorts of good battery information sites.
There is so much information out there about batteries that it can be confusing. And, on top of that, much of the discussion gets way past what an RV enthusiast needs in technical detail and laboratory precision. Used to be we were happy just watching how the lights dimmed when the water pump or furnace came on. Nowadays it seems folks want to know the exact minute when they will run out of juice predicted days ahead. Some things just ain't gonna' be.
Old 11-29-2008, 11:48 AM   #12
1986 31' Sovereign
Miami , Florida
On my '86 Sovereign, the converter/charger is under the couch up front. If it is the original Univolt, you should be able to hear it humming whenever you are plugged into shore power.
mike
n2916s is online now   Reply With Quote
Old 11-29-2008, 02:07 PM   #13
Mexray's Avatar
1978 28' Ambassador
Morada , California
Bryan,
I couldn't agree more...keep it simple when it comes to RV battery information.
I deal with RV battery problems every week in my business, and I believe about 90 percent of the RV'ers don't have a clue as to what's going on in their RV, battery wise!
Most contributors on this Forum aren't in that 90 percent group - they've taken to time to learn what goes on inside their AS to get the most out of them, etc.
I'm sorry though, most all electronic battery testors I've seen are akin to snake oil products...sure, they'll measure the voltage, maybe the internal resistance, and then flash some lights to indicate 'good' or not...but not much more...if you read some of the links in depth that you've listed, you will note they are talking about 'single cell' battey testing...when it comes to multiple cell batteries...IE, RV 6 cell (12 volt) or 3 cell (6 volt) batteries, these 'electronic' devices can only average out the results to give you a 'reading'....if you have one weak cell, it won't tell you squat - only the 'average' of the cells...
Sure, if you have a sealed top, maint free type battery, you can't use a hydrometer, and must use a voltmeter to get some kind of indication of the batteries condition...the load tester will be the only true device to let you know if their's a weak sell - and only AFTER the battery has been charged...you can't find a leak in a tire till you pump it up with air...same with batteries, you can't load test without first charging.
Also...if you have battery problems, seek out a Battery Specialist in your area...most local auto parts stores don't have the experience or knowledge to provide the answers an RV'er might need for his battery system...the Battery Specialist will give you the straight scoop...
In the vein of keeping things 'simple'...
1. keep your batteries charged when not in use.
2. keep the terminals clean and free of corrosion...use some heavy grease to coat exposed metal parts and cable ends will help.
3. Don't leave your AS plugged into shore power if you have an older Univolt converter/charger, as it will overcharge your batteries, evaporate the fluid, and ruin them.
4. always recharge your batteries as soon as possibe after use...use a daily charging schedule if you're boondocking to insure you're getting back to full charge.
5. larger battery banks are great for longer running times, but take lots more time to recharge...there's no free lunch here, what comes out of the batteries must be replaced!
Old 11-29-2008, 03:42 PM   #14
1977 31' Sovereign
Images: 33
What you did this with a older univolt?
Originally Posted by Mexray View Post
Bryan,
Use a appliance timer and have it go one for a few hours a day. that would keep it from over charging.
K/N Cool intake air
Duel power exhaust
Tru charge battery charger install? nsteel Batteries, Univolts, Converters & Inverters 0 11-21-2007 07:09 AM
How Long Should an Idle Battery Hold Its Charge SilverCabin Batteries, Univolts, Converters & Inverters 26 04-24-2007 05:43 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
Battery Charge from Tow Vehicle Wardinbb Batteries, Univolts, Converters & Inverters 13 12-08-2004 05:35 PM
How to wire truck to charge TT battery? femuse Electrical - Systems, Generators, Batteries & Solar 19 04-09-2003 10:23 AM
