Old 03-04-2014, 12:34 PM   #1
Battery Cable Identification Help
Hey guys - In the next few days I'll be moving from 12v batteries to two 6v batteries. I want to make sure I don't mess up the wiring in the process and could use the forums help to identify some cables running to my existing setup (from a previous owner). Below is an image of my batteries and my best guess as to what they are being used for. Feel free to correct me if I'm wrong.
1) Used for parallel connection, I won't need this for the two 6v
2) The main negative line, this will be attached the negative battery terminal that's not used to connect the batteries in a series
3) Ground wire? Same as above, connected to negative battery terminal
4) I'll use this to connect the 6v batteries into a series, going from positive to negative on separate batteries
5) ???? might be related to audio
6) ???? might be related to audio
7) I believe this is for the electric tongue jack, will be attached to the positive terminal
8) The main positive line, this will be attached to the positive battery terminal that's not used to connect the batteries in a series
AirGal04 is offline   Reply With Quote
Old 03-04-2014, 01:23 PM   #2
1977 Argosy 24
Milltown , Wisconsin
Looks to me like you have it right. Who knows what 5&6 are for without tracing them. I do not think #4 will be long enough to go from the positive to the negative on your 6 volt series batteries though.
ventport is offline   Reply With Quote
Old 03-04-2014, 02:11 PM   #3
richw46's Avatar
Lexington , Kentucky
As I see it, 8 (pos) and 2 (neg) become the primary connections, cable 1 goes to 5 to put the 2 batteries in series. (it's the longer of the 2 cables) 4 comes off.
I'll bet 5 & 6 go to the inverter. That looks like an in-line fuse on 6.
5 neg would go to 2 neg, 6 & 7 pos would go to 8 pos.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 03-04-2014, 08:35 PM   #4
Thanks guys, that's what I wanted to hear. I noticed the green wire does actually make it inside the trailer, not sure if it would still be ground wire. Regardless, I think the transition to 2 6v should go pretty smoothly, crossing my fingers.
Old 03-04-2014, 08:55 PM   #5
richw46's Avatar
Green is typically a chassis or case ground. In small appliances it's the middle / round / third prong on a 3-prong plug.
Of course, that's what it's supposed to be. If you have a multimeter you can do a continuity test between the green terminal on the negative post and the AS shell to be certain. It may also go to the main bus and be used as another type of ground. Nevertheless, it should be a ground of some sort, maybe for the electric tongue jack.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 03-06-2014, 07:23 AM   #6
Skater's Avatar
1995 30' Excella
Bowie , Maryland
In DC wiring, the wires are much more colorful than in AC wiring. I wouldn't rely on the green is ground rule; for example, in my trailer, green is the running lights positive wire. Black and red are the only ones you can kinda sorta sometimes rely on, and there's even a counterexample in that picture (black wire going to positive terminal, the red tape indicates its positive, which is great, but if you saw that mid-way through the run you'd have no idea). You really need a voltmeter to do much beyond looking at 12 volt wiring.
In this case, though, that green wire is definitely a ground for something, since it's hooked to the negative terminal. It's a little small to be a chassis ground for the trailer. Probably the negative wire for the tongue jack or something like that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-31-2014, 09:11 PM   #7
Dean E's Avatar
1989 32' Land Yacht
Oakton , Virginia
[QUOTE=AirGal04;1423136]Hey guys - In the next few days I'll be moving from 12v batteries to two 6v batteries. I want to make sure I don't mess up the wiring in the process and could use the forums help to identify some cables running to my existing setup (from a previous owner). Below is an image of my batteries and my best guess as to what they are being used for. Feel free to correct me if I'm wrong.
I would install a 30-amp, slow-blow fuse at the battery--in case of a short somewhere between the jack and the battery.
The jack would probably have the same fuse near the jack.
In other words, the safest route is to have two fuses on this line.
Dean E is offline   Reply With Quote
Old 03-31-2014, 09:56 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Deleted
Where to find battery cable Lexgirl Batteries, Univolts, Converters & Inverters 3 01-05-2012 07:26 PM
2011 International EXT cable hookup not working alozier Audio, Video & TV 6 10-20-2011 03:42 PM
How long can my battery cable be - and what gauge wire? robwok Electrical - Systems, Generators, Batteries & Solar 3 10-20-2011 09:52 AM
1970 31ft sovereign international battery cable question travalota Batteries, Univolts, Converters & Inverters 1 09-27-2011 06:53 PM
