Old 01-31-2019, 11:01 AM   #1
2017 27' International
Box Elder , South Dakota
Batteries vs Inverter
How to distinguish between bad batteries and a bad inverter or something else: I seldom use the inverter outlets. I am usually plugged into 30 amp shore power. And usually the battery indicator will read 13.something, like 13.5 or whatever. Yesterday the indicator started reading 12.7 or thereabouts. With the help of a more knowledgeable friend, we disconnected the battery and charged it overnight. Not all the way but it tested above 13 before I became impatient. It is now back down to 12.7. Of course I had no lights, radio, TV antennae overnight. And incidentally I could not get the refrigerator to switch over to propane, it stayed off as well as the refrigerator lights. I am guessing it is the inverter that is bad as that would cost the most money to fix. (snark, snark) I have a supplemental 7 year warranty with the dealer which involves driving 1000 miles to the dealer to have them look at it. The batteries are two years old, the 1000 watt pure sine wave inverter came with my brand new 2017 International Serenity. Is there further testing I can do or should I just buy two new batteries and see if that solves the issue? Thanks.
alphamale49 is offline   Reply With Quote
Old 01-31-2019, 11:08 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
12.7 volts is 100% SOC for rested batteries. Is your “Use” switch on?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-31-2019, 11:54 AM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
If you were plugged in and had no 12v power, the problem would be your converter (battery charger), not your inverter. The inverter converts 12v dc to 120v ac.
Dan
Old 01-31-2019, 11:56 AM   #4
First of all let me apologize. My friend now says he misspoke and the problem may be with the converted, not the inverter. And I am really confused if you are not. The switch is set to 'use' and the little light is on. I always have it set that way.
Old 01-31-2019, 12:01 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I don’t see a problem. Does everything work? Here is a voltage table. You want to keep your batteries above 50% SOC (state of charge). I would get a volt meter and mount it permanently.
DanClick image for larger version
ID:	332701Click image for larger version
Old 01-31-2019, 12:08 PM   #6
I am plugged into 30 amp shore power, the battery is reconnected and the switch set to 'use' Everything works, the indicator now says 12.9. So maybe there never was a problem? But why did the indicator always say 13.5 before I manufactured this crisis?
Old 01-31-2019, 12:20 PM   #7
LDM
2018 25' Flying Cloud
Jonesville , Louisiana
Sound like your converter slow it charging rate back as the batteries are getting close to full charge. That is what it should do. When plug in to shore power you are getting the charging rate on your battery. If you want to get Just battery rate un plug from shore power.
LDM is offline   Reply With Quote
Old 01-31-2019, 12:22 PM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Because the converter was charging the battery and the charging voltage at the converter was 13.5 volts. The charging voltage needs to be higher than the battery voltage for the batteries to take a charge. If you want to know the battery voltage when you are plugged in you need to unplug your Airstream or unplug your converter.
Dan
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Lifeline Batteries and Magnum Inverter Beach Bum Airstream Classifieds 7 12-14-2015 09:37 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Replace House Batteries (Magnum Inverter) MILATV Sprinter and B-van Forum 24 11-04-2014 06:11 PM
Mixed batteries and surprised with converter/inverter outofcontrol Batteries, Univolts, Converters & Inverters 14 05-08-2014 09:04 PM
