05-24-2017, 08:06 PM
2015 27' FB International
Wheatley
, Ontario
Batteries uninstalled...can I connect shore power safely?
I own a 2015 27 FB International Signature. I noticed my batteries would barely hold a charge, I found out they are "unstable" according to a load test. So I removed them and are waiting for replacements.
My question is, can I connect the shore power without batteries being installed? I don't want to damage anything.
Thank you in advance......
05-24-2017, 08:30 PM
2015 30' Classic
Pleasanton
Yes, the converter can be used without batteries connected. This is essentially what happens when the Use/Store switch is in the store position.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
05-24-2017, 09:06 PM
1974 Argosy 26
Morrill
, Nebraska
Just tape off the battery leads so they don't short out.
05-25-2017, 04:47 AM
Wheatley
, Ontario
thank you guys!
I tried googling this issue before posting here, a lot of conflicting statements out there. Just love this forum and its helpful members :-)
05-25-2017, 11:44 AM
2014 27' FB International
Sugar Land
Proceed with confidence the above answers are correct.
05-25-2017, 12:15 PM
2016 25' Flying Cloud
Friday Harbor
A related question about battery connecting
As a newbe, I was surprised recently when on shore power, the power died (in a windstorm) lasting for two hours but I could not get the battery to kick in. I have a FC25, 2016. On the inverter remote control switch (green light) when I pushed the on/off switch the light went on and off. On the battery disconnect switch pushing the use/store switch changed nothing (the red light stayed on). So when I do not have shore power or shore power is not working, how do I get the battery to come on? Thanks for insight.
05-25-2017, 12:47 PM
2012 25' FB International
Trent Woods
, North Carolina
The USE/STORE switch will always be lighted when connected to shorepower. If not on shorepower it will be lighted only when in USE, which connects the batteries to the DC loads. I am not sure what you mean by getting the battery to come on. If you lost shorepower and also all DC there are only two possibilities: your switch was in the STORE position or the batteries are discharged. There have been a few reports of the relay not operating the switch but that seems somewhat rare. If your batteries are shot, you would not know when connected to shorepower as the converter supplies the DC.
Larry
05-27-2017, 06:21 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
NO!
Batteries, even 'pooched' batteries, act as an accumulator, (snubber) which protects against voltage spikes, and heavy amperage flow.
Without them, your eguipment can be Slugged with damaging loads.
05-27-2017, 10:23 PM
1974 Argosy 26
Morrill
, Nebraska
You have a modern converter therefore there is no risk of a surge.
You can safely use the 12 volt system without a battery.
Per my previous post just protect the battery cables from shorting out.
05-28-2017, 07:05 AM
Blenheim Ontario
, Ontario
To each his own!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Batteries Shore Power
willyd |
Batteries, Univolts, Converters & Inverters |
10 |
07-28-2021 10:44 PM |
Should I unhook batteries from shore power?
flyfishrra |
Electrical - Systems, Generators, Batteries & Solar |
14 |
08-30-2012 05:16 PM |
Hooking to shore power with batteries removed?
AUTAILGATER |
7 |
06-02-2011 09:36 PM |
Should I physically disconnect batteries if on shore power for 30+ days?
foqus |
23 |
11-21-2009 05:34 PM |
Using shore power w/o batteries 1989 Excella 1000
VABelson |
4 |
12-29-2007 09:58 PM |
