Old 03-17-2005, 11:08 AM   #1
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Batteries Short...New Converter
I have to replace the two dead shorted batteries that are two years old from Sam's Club to put into my 34' Limited TT, 1985 model. My converter went bad and I hd a new one put in. Just wondering about the new batteries, and looking for advice on what should I buy, and from where, for the best deal? I need these for the upcoming Cherry Blossum Rally next month.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 03-17-2005, 01:01 PM   #2
Images: 59
What brand converter?
Old 03-17-2005, 06:27 PM   #3
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Rob
Since you're replacing both batteries at once consider going to two 6 volts "golf cart" batteries.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 03-17-2005, 06:34 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I believe that would be four 6 volt batteries to better his present capability.
Tom
Old 03-17-2005, 06:48 PM   #5
1997 30' Excella
Waddell , Arizona
Images: 13
Tom
It takes two 6 volt batteries to equal the voltage of one 12 volt, but two 6 volt batteries will almost always have more reserve capacity than two 12 volts batteries.
Steve Heywood
Waddell, AZ
Old 03-17-2005, 06:56 PM   #6
TomW's Avatar
1967 26' Overlander
...but two 6 volt batteries will almost always have more reserve capacity than two 12 volts batteries.
I find that believable even though that was obviously not my first thought.
Believable is the key word; Hopefully others will chime in.
Tom
Old 03-17-2005, 07:00 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rob
go with marine starting batteries of the 650 cca range.
they will give you the best bang fer your buck.
john
you call them ferrets, i call them weasels.
Old 03-17-2005, 07:49 PM   #8
Images: 59
Unless we know what type of converter/charger you have, it's difficult to make a recommendation. If you have a three stage charger, it may be worth investing in good quality AGM batteries.
If not, then just get cheap wet cells (6V or 12V) because you'r just going to boil them out and need new ones in a couple of years anyway.
It would also help if we knew more about your type of camping. If you dry camp and don't have hookups or a generator, the type batteries you want will be different than if you always have electrical hookups.
Old 03-18-2005, 08:38 AM   #9
robandzoe's Avatar
Plymouth , New York
Charger
I had a 7400 Series Parallax Converter / Battery Charger in. Which one in the 7400 series, I have to find out exactly. Don Mar here in SC put it in.
Rob
Plymouth, NY 13832
Courtesy parking
Old 03-18-2005, 08:39 AM   #10
robandzoe's Avatar
Plymouth , New York
Type of camping
We usually are at a campground with hook ups or I have my generator. Hope this helps.
Rob
Plymouth, NY 13832
Courtesy parking
Old 03-18-2005, 08:51 AM   #11
1997 30' Excella
Waddell , Arizona
Images: 13
6-Volt vs 12-Volt batteries
One thing I didn't consider was battery location. As long as the batteries are located next to each other it's very simple to replace two 12-volt batteries with two 6-volt batteries. However, if you have an Excella/Classic with the two seperate batteries compartments it would be difficult (at best) to use two 6-volt batteries.
If someone know a simple way (to use two 6-volt batteries in an Excella/Classic) I'd sure like to hear about it!
Steve Heywood
Waddell, AZ
Old 03-18-2005, 09:27 AM   #12
Generally speaking, replacing 12 volt batteries with two 6 volt batteries, is not recommended.
To use 2-6 volt batteries, they must be wired in series. Should one of them fail, or become weak, you will have no power.
In the case of 2-12 volt batteries wired in parallel, should one fail, simply disconnect it and your still in business.
Additionally, battery capacity is measured in watts. Therefore, of a given physical size, a 6 volt battery does not offer any more wattage, than a 12 volt battery.
Basic ohms law applies. Batteries in series, increases the voltage, not the current available. Batteries in parallel, keep the same voltage, but the current available increases.
Therefore the wattage stays the same, between the 6 and 12 volt setups.
Bottom line is there is no advantage to using 2-6 volt batteries in series, in fact you gain a disadvantage, since you have to rewire.
Golf carts are far removed from an RV when batteries are the topic.
Keep in mind what happens to simple Christmas tree lights that are wired in series, as opposed to parallel. In series, when one goes out, the entire string quits. In parallel, when one goes out, the rest of the lights still function.
And finally, again generally speaking, the cost for 2-6 volt batteries is greater then their equal in 12 volts. Simply supply and demand.
The formulas are simple E=IR I= E/R R=E/I
For wattage. W=EI
E=voltage
I=Current
R=Resistance
W=Wattage
As an example, take two 6 volt 200 amp batteries, (1200 watts) and wire them in series. You will have 12 volts at 200 amps, which also equals 2400 watts.
Then take two 12 volt batteries at 100 amps each (122 watts). Wire them in parallel and you then will have 12 volts at 200 amps, or 2400 watts.
The point being, you gain nothing by using 6 volt batteries. Practical experience, bears that out.
Old 03-18-2005, 09:32 AM   #13
Images: 59
Rob,
I am not familiar with the Parallax 7400, but I believe it is a single stage charger/converter. These chargers may overcharge the batteries if left hooked up continuously. That may be what ruined your previous batteries.
I would recommend you buy a pair of cheap deep cycle 12V batteries, based on Steve's observation. I wouldn't use marine starting batteries, or combination starting/deep cycle. Go straight deep cycle. They're inexpensive and you can replace them every year if you need to.
If you want to see a totally overboard analysis of battery selection and life cycle costing, look at this guy's analysis:http://www.vonwentzel.net/Battery/index.html
postscript: if you spend most of your time 'on grid' at a campground, you may not need two batteries. Just try one battery for awhile and see if it works.
Old 03-18-2005, 09:58 AM   #14
Parallax 7400 charger, more specifically, the 7455 model, has been used by Airstream, in production, for several years.
The charger company name has changed, but the charger proper is the same.
If it overcharged, Airstream would have quit using it years ago.
It is a superior charger, therefore Airstream will continue to use it.
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
