06-11-2018, 02:31 AM
2018 33' Classic
Mendham
, New Jersey
Batteries run dead with shore power
Hi friends.
2018 33ft Classic - Camping for the weekend connected to shore power and coach batteries keep discharging and are now nearly dead. They do charge up from my TV when I drive. Any tricks I am missing. (No tripped circuits.)
Thanks a million.
06-11-2018, 08:56 AM
Airstream Ambassador
Jackson Center
, Ohio
Hi hjnj,
We are very sorry for the issue that you are having with your 2018 Classic. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
We look forward to helping you get this resolved. Thank You.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
06-11-2018, 12:17 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Best bet is that either the converter charger is broke ( it ...err ... does happen ....) or that the breaker that feeds the charger has tripped. Either way it's something that an AS dealer should look into.
06-11-2018, 12:21 PM
2007 22' International CCD
Corona
Remember to reset an 120v AC power breaker, you must turn it fully to the 'off' position, THEN turn it back to 'on'.
This resets the breaker properly. Just pushing the handle back to 'on' does not reset the breaker.
Yep, it sure sounds like no 120 volt power into the converter, or a dead converter...
06-12-2018, 03:11 AM
2018 33' Classic
Mendham
, New Jersey
Thanks Uncle Bob
06-12-2018, 03:13 AM
2018 33' Classic
Mendham
, New Jersey
Thanks for the info. Checked breakers again. All seem to be in ON position.
06-12-2018, 03:16 AM
2018 33' Classic
Mendham
, New Jersey
Originally Posted by AirstreamInc
Hi hjnj,
Thanks! Sent you info by PM. Looking forward to hearing back from you.
06-12-2018, 05:58 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Do you have two shore power connections?
Does anyone know if AS has upgraded the transfer switches?
Could be a TF switch failure.
06-12-2018, 09:44 AM
Tifton
, Georgia
It may seem to be on, but I would totally reset it---switch it off then back on. Circuit breakers can shut off but the handle appears to be on. A lot of times if you run your fingers along the outside of the switch, you can feel it isn't exactly in the right position. A total reset could fix it. I would still have AS look at it.
06-12-2018, 10:41 AM
2017 25' International
Framingham
, Massachusetts
Okay. I’ll ask the obvious. Is the battery disconnect switch turned on? A few items are wired directly to the battery and will drain it...usually in more than just a weekend though. With the 2018 converter, the battery disconnect can be left on so that the batteries will charge (but not overcharge) while connected to shore power.
06-12-2018, 10:54 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
A lot depends on how that specific trailer is wired. Some have the converter on one side of the disconnect, others have it on the other side of the disconnect. There are indeed examples of the same make / model / year / floor plan from the same month being wired differently. No idea if it was a mistake ( wire bolted to wrong post ), something done by the dealer ( = customer request maybe), or a running change.
06-12-2018, 11:02 AM
Framingham
, Massachusetts
Hi
I’m just going off of how a 2018 is SUPPOSED to be wired. Recall that in 2018 Airstream switched to a multistage converter/charger and an entirely different type of battery disconnect switch/system from previous model years to solve some of the problems understanding exactly what happens when the disconnect is on or off and to prevent overcharging of the batteries.
06-12-2018, 07:02 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
They still have the latching relay for the use/store stuff. Put the charge cable on one lug and it disconnects from the battery. Put it on the other lug and it never comes off the battery no matter which way the relay is latched.
06-12-2018, 08:16 PM
Corona
Yup. Exactly right. Had to reconnect my solar controller because I managed to mix up the terminals when we installed it.
