Old 11-01-2005, 05:31 AM   #29
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Originally Posted by john hd
keep in mind that the plug is now energized all the time, if you stop for the night and run your furnace you may need a jumpstart in the morning!
that is why i isolated my second battery as shown in the above thread.
you can just pull the plug when you park...
john
This is not the same on all vehicles. My Tundra only powers the trailer when the ignition is on.
Richard
Old 11-01-2005, 07:54 AM   #30
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
had a very similar situation last year. didn't seem like I was getting any charge from the TV. Turned out that I had blown the fuse that is located in the distribution box under the hood.
In this case, Dodge DOES install the fuse at the factory in trucks equiped with the tow package. However, they DO NOT tell you anything about it. there is no reference to this fuse, or any other under-the-hood fuse, in the owner's manual. I had to find out of its existance, and location from my friends on the dodge truck forums.
another thing specific to dodge: there is power to this circuit 100% of the time, regardless of the position of the ignition switch.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-01-2005, 08:31 AM   #31
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I remember long ago that when you wired your TV for towing, adding a battery isolator was standard fare. I've just gotten into the habit on overnights where we stay hitched up, to pull the trailer's plug out of the TV, just in case. I've never checked the pins on my GM van to see if I could pull power after the ignition is turned off.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-01-2005, 09:13 AM   #32
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
My Chevrolet van also only powers the pin when the key is on, and the engine is running. I haven't seen this on other tow vehicles I have owned, but it seems like a good idea.
Old 11-04-2005, 10:40 AM   #33
redeagle313's Avatar
NE , Indiana
Thanks to everybody on this thread, it reminded me that on a recent trip with the new TV, I had no battery charging, so I did a quick check on my new TV, and the dummy plug was still in it. It has been replaced and I am good to go. Thanks All!
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 01-31-2006, 12:55 PM   #34
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
And thanks to you all once more - after running out of juice in the Smokies last fall, I was puzzled that not even driving all day was enough to get even a little charge.
I found this thread, found the dummy fuse right where you guys told me, plugged in a 40amp fuse and now am in business. Sure is hard to figure why Chev doesn't install it in the first place. Or at least mention it someplace.
By the way, just in case you haven't had the pleasure of having your battery going completely dead at bedtime, the propane detector peeps at irregular intervals all night long when it doesn't have sufficient power to operate. (The bells, the bells - arrggh).
Thanks again - Pat
pmclemore is offline   Reply With Quote
Old 01-31-2006, 01:36 PM   #35
jcanavera's Avatar
Fenton , Missouri
Images: 143
Thanks again - Pat
Pat, I can only speak for the van side of the world and I was in the same boat with my Chevy van and now my GMC. In this case I assume they put a dummy inplace due to the fact that the factory towing package wiring on vans is not terminated into a recepticle in the rear. On some of my older GM vans the hot lead was not terminated under the hood but left as a wire with a round loop connecter on it.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-31-2006, 06:38 PM   #36
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by wildwoodrver
Mystery resolved. GM ships these vehicles with a dummy fuse in the fuse box. A quick call to the excellent support staff at GM resolved it. Unfortunately, the fuse is labeled "Stud 1." The description is auxillary power. It was pretty obvious as it was the only "dummy" in place. I guess they wanted to leave the option open to use it for other "auxillary" purposes (not just trailer charging circuit).
So with a 40 amp fuse in place, I get 12v at the pin on the back of the car. I was interested to read in the owners manual that if you want to boost the charge to the trailer, drive with the headlamps on. Gotta go camping now to test it!
The support rep told me they actually ship the vehicles with a fuse in the glove box. I didn't find it, but the car is a year old.
Thanks one and all. And yeah! What response! 24 in 24.
My '01 2500hd came with the rolled up harness to plug into the under dash convenience center and then to the brake controller. A tag with instructions complete with drawing of where the plug was to go was attached. I can't remember if the 40 amp fuse was taped to the tag or if it was in a small envelope attached. It sure made things easy.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-22-2008, 05:33 PM   #37
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
look for a battery isolator
mustang is offline   Reply With Quote
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
