Old 02-01-2016, 07:41 AM   #1
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Batteries Not Charging
I used an extension cord from my garage to plug into AS to charge my battery. I used a simple 30amp to 15amp puck style adapter from the AS power cable to extension cord. The battery was at 9.6v when I started and the next day was still around 9.6v. Is there something I did not do correctly?
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 02-01-2016, 07:46 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
If your switch was in the "Store" position, your battery was not connected. Check to be sure it is in the Use position. The light will be red whenever plugged into shorepower, either position. If your battery voltage was that low it is already bad and I would recommend replacing them. Some would just recharge but they will never have rated capacity again. You should not let the voltage go below 11.9-12 vdc.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-01-2016, 12:17 PM   #3
Manassas , Virginia
So I would still need to press the switch to use even though it is lit up already? I assumed that once plugged into shore power the battery automatically would connect and charge itself. I guess I assumed incorrectly. BTW - it has only been that low for a short amount of time due to use.
Old 02-01-2016, 12:59 PM   #4
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
You are just energizing the common DC bus if it's in store, the battery is not connected until you hit the switch.
Old 02-09-2016, 08:34 AM   #5
Manassas , Virginia
That was the ticket...thanks
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 28 12-16-2017 06:32 AM
Coach batteries not charging RetiredGuy Batteries, Univolts, Converters & Inverters 0 08-10-2009 04:00 AM
Batteries Not Charging With Generator timkim Batteries, Univolts, Converters & Inverters 5 08-09-2009 06:30 PM
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 05:33 PM
Motor Home batteries not charging myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 17 06-20-2008 10:58 AM
