Old 03-18-2012, 07:58 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Batteries grounded correctly?
When I got my 23FB, the batteries were wired as shown in this picture. Is this correct in terms of the grounding cable? It seems odd to me that it goes from the positive post to the chassis ground as shown by the smaller black cable going to the right lower corner of the attached picture.
bonginator is offline   Reply With Quote
Old 03-18-2012, 08:09 PM   #2
If the red wires are indeed on the positive terminals, then the small black wire should be attached to the large black wires, which then are the negative treminals.
Old 03-18-2012, 08:14 PM   #3
1974 Argosy 20
Kooskia , Idaho
I can't see where the other end of that small black cable goes. Are you sure it is not going to some place like the break away switch, or the tongue jack. If it were connected to ground, you would have a dead short and burned up cables or some other disaster.
Old 03-18-2012, 08:16 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Are you sure that small black wire runs to ground? Could it be to the break away switch to power the brakes in case of a separation from the tow vehicle?
If it were going directly to ground from the positive side it would most likely melt, with two batteries wired parallel you have a lot of amperage (only 12Volts).
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-18-2012, 09:14 PM   #5
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
It looks right. I think that small black wire is for the tongue jack and will be fused somewhere between there and the jack. Disconnect it and see if the jack stops working? You would think the wire would be red but the ones I have seen are black too.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 03-18-2012, 10:33 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
My money is on it being the feed to the tongue jack.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 03-18-2012, 10:37 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it's the tongue jack wire; Mine is the same. If that was a ground wire, it would have melted instantly.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-18-2012, 11:09 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Black is positive and White is negative in/on the trailer. It looks like it is wired correctly. In automotive wiring Red is positive and Black is negative. It is virtually impossible to find a White battery cable. That is why it can be confusing.
I don't know who the rocket scientist was that came up with black and white in a trailer. Maybe they didn't understand the trailer would be connected electrically to a car or truck with red and black cables. Duh!
Old 03-18-2012, 11:13 PM   #9
Boulder , Colorado
Vinnie
I didn't think of the possibility Of it being the tongue jack. I will check that when I am back at the the trailer.
Where to add additional batteries demondeacon3 Batteries, Univolts, Converters & Inverters 32 10-23-2012 10:11 PM
installing 4 6 volt batteries on Safari 27 FB The Driver Electrical - Systems, Generators, Batteries & Solar 8 05-12-2012 07:08 AM
batteries la nomade Classic Motorhomes 24 04-19-2012 03:57 PM
Can I charge my drained interstate batteries? bonginator Winterizing, Storage, Carports & Covers 17 04-01-2012 08:16 AM
Odyssey Batteries, your experience? SteelyDan Classic Motorhomes 14 02-28-2012 12:06 PM
